Old 01-15-2013, 04:32 PM   #1
golonaus's Avatar
Will 18" wheel with 285/30 and 37 offset fit on 986 with 1"drop?
As title says
What'd do you guys think?
I'm running 46 offset now but would like to go wider for more aggressive look
It's 99' 986
Old 01-15-2013, 05:15 PM   #2
LAP1DOUG's Avatar
No way on the front. My car is lowered about 1" and I recently tried fitting some 265 StarSpecs, which actually measure at 272 mm section width that I had laying around on 43mm offset wheels. They looked like they sort of fit at first until I turned the steering wheel only about 1/4 way to full lock, and the tire hit the body. Not the fender liner, but the body. A 37mm offset would be even worse. I would think you need about a 50 mm offset to fit a 265 tire.
On the rear, it might work depending on the actual section width. My measurements indicate we need a 43-47mm offset to avoid contact with the wheel well, so I have doubts about a 37mm offset working.
Kippis
986S
991S
Van Diemen RF97
LAP1DOUG is offline   Reply With Quote
Old 01-15-2013, 05:25 PM   #3
golonaus's Avatar
I'm obviously asking about rear wheel
No turning there
I'm running this setup now with 46 offset with room to go farther(I think)
Old 01-15-2013, 05:29 PM   #4
LAP1DOUG's Avatar
Yeah, I figured that out after posting initially, so see edit above. The 46 offset seesm to be ideal for the 285 tire you are running. So, go take some measurements.
Kippis
986S
991S
Van Diemen RF97
Old 01-15-2013, 06:28 PM   #5
Johnny Danger's Avatar
Originally Posted by golonaus View Post
As title says
It's 99' 986
What is the width of the wheel ?
Old 01-15-2013, 07:07 PM   #6
golonaus's Avatar
It's 10 inch
Old 01-15-2013, 07:22 PM   #7
JAAY's Avatar
That's what she said. :dance::dance::dance::dance::dance::dance:
JAAY is offline   Reply With Quote
Old 01-15-2013, 07:28 PM   #8
golonaus's Avatar
I'm alway saying that you got to be optimistic these days
Old 01-16-2013, 04:03 AM   #9
It's 10 inch
I view of the fact that your vehicle has been lowered, I think reducing the offset any more than 5mm's with a 285 tire will potentially create a clearance problem with regard to the fender lip. In the event you were running a 275, I'd feel more confident in saying that you could lower the offset by another 10mm's.
Old 01-16-2013, 05:06 AM   #10
golonaus's Avatar
Thx a bunch sir.
