Old 01-04-2013, 06:13 PM   #21
l3m
l3m's Avatar
Watch this video of insite. Effortless hand movements.
'01 S
l3m is offline   Reply With Quote
Old 01-04-2013, 06:58 PM   #22
Originally Posted by rondocap View Post
What do you guys do at stop lights? I anxiously try to read the other side and predict when it will turn green, so I have time to go from neutral to 1st and get ready.
If I wait to shift to first when the light turns green, it takes me a couple of seconds because I have to go to first, and slowly release the clutch so I don't stall. An automatic can just hit the gas and go, but we have a few extra steps.
So what do you do or think is best?
When I come to a stop, I shift into first (clutch depressed) and leave it there until the light turns green. If you're going to neutral (no gear selected) to avoid keeping the clutch depressed through the light, you either need to hit the gym to strengthen your legs or move to a city that doesn't keep you at stoplights so long.
+1 with Particlewave re: "On a steep hill, I'll usually hold the e-break up with the button depressed to keep from rolling back any."
It takes some practice to coordinate simultaneous release of both clutch and e-brake to avoid either a roll-back or a stall, but once you are good at it, it becomes another grin-inducing act that you just can't get driving an automatic.
Bear
dbear61 is offline   Reply With Quote
Old 01-04-2013, 08:38 PM   #23
mcomet's Avatar
I don't know about worrying... I tend to go to neutral when approaching a stop. Much easier than down shifting to first. If the light changes as I am coasting, I drop into whatever gear makes sense, usually second. If I am totally stopped I try to "spy" the light change and get ready to go. That said yes, it will be slower being in a manual car. I also feather the gas above 1000k a bit as a prev poster mentioned to get a smooth start. I am sure some people are like wow..slow Porsche...but whatever they can wait. This is for a normal start. And we'll if you are a second behind the other car, it is usually pretty easy to catch up..
Michael Comet - www.comet-cartoons.com
2014 Guards Red Cayman S - PSE - PASM - 20"CC - INFTMT - CONV - etc..etc...
SOLD - 2003 Speed Yellow Porsche Boxster S - LNE IMS - Klisstle Rollbar Cover
mcomet is offline   Reply With Quote
Old 01-05-2013, 04:36 AM   #24
It's a bad idea to keep the car in gear with the clutch depressed at lights. It increases wear on the release bearing, and puts pressure on the crankshaft thrust bearings. And yes, you will be a split second slower off the light than an auto car, so what, they'll get over it.
Old 01-05-2013, 07:22 AM   #25
That's why I i didn't keep it in first, I thought it wore parts down vs putting it in neutral while stopped.
People do get very impatient when you take a little longer, or stall.
rondocap is offline   Reply With Quote
Old 01-05-2013, 07:47 AM   #26
mcomet's Avatar
If you are still stalling just get more practice. And remember to give it some gas as you let off the clutch.
