Old 11-05-2005, 02:53 AM   #1
container for used oil
Some clothes washing detergents like Tide are coming in a 300 ounce container with a nice tight screw top. This is a nice way to carry the waste oil to a disposal point. It hold about 9-3/8 quarts so you'll find that the complete drain fits perfectly. It also has a wide opening. I always hated pouring the oil into the old quart containers as it always seemed to create a mess.
Also, if you are a cat lover, I've noticed that some cat litter comes in containers that are probably large enough to store a complete drain.
John from PA
John from PA is offline   Reply With Quote
Old 11-05-2005, 03:47 AM   #2
Thanks for the tip.
Biz-z Z is offline   Reply With Quote
Old 11-05-2005, 04:48 AM   #3
donv's Avatar
Depending upon your location, you may not be able to do this and get "free" recycling of the oil. For instance, in Mass., retailers are required to take back the oil they sell. However, the policies of the retailers vary. Wal-Mart will only take back the oil in the original containers (an oil bottle, not necessarily the same oil bottle ). AutoZone (or whatever they're calling themselves this week) would only take the oil in bulk, so they'd just drain it out of thesingle container you give them and then hand that container right back to you - as a result, I just use a resealable drain pan (which they sell) to drain the oil into and then transport it back to the store.
Bottom line, to save yourself a hassle, be sure to call or ask ahead to know what the policies/regs are in your area.
2001 Lapis/Black/Black, PSM, Rear Speaker Kit, Optima...
donv is offline   Reply With Quote
