Old 12-05-2012, 01:01 AM   #1
More's Avatar
Braking Hard!
So I've been hitting the brakes hard to lose the squeek noise you get after a car wash the old accelerate to 80/100km and then hit the brake hard but now I can hear a rubbing sound coming from the front left tire is this from breaking too hard?
1998 Porsche Boxster 986 Convertible.
More is offline   Reply With Quote
Old 12-05-2012, 05:09 AM   #2
Ex Esso kid
When the brakes are in proper condition hitting them hard should not produce an ongoing noise miles afterwards. Something needs to be looked at, could just be a pad hanging up or rubbing the rotor edge, pull the tire and visually inspect or post pic.
Old 12-05-2012, 07:09 AM   #3
Maybe your new BIGGER wheels are rubbing the wheel well.
Use your leaf blower after a car wash to dry the wheels, barrels, calipers, and cross drilled rotors.
Old 12-05-2012, 09:18 AM   #4
There's no reason to hit your brakes HARD to eliminate water from washing. I rarely do anything, so what if they stick a bit when you take off the next day, they clear with the first stop.
Old 12-05-2012, 10:15 PM   #5
Topless's Avatar
Brake pads worn out on the inside of the rotor?
