-   -   help! loud rattle in front of engine ... (http://986forum.com/forums/boxster-general-discussions/4108-help-loud-rattle-front-engine.html)
Moostang 10-30-2005 10:39 AM
Im hearing a loud rattle from the front of the engine compartment... i have the cover off and can't diagnose. Sound seems to get softer as u apply gas. help!
MNBoxster 10-30-2005 07:59 PM
Hi,
Well, since you don't know what it is, I'd avoid running the engine excessively until you isolate it, that's just a good practice.
To try and isolate it, take a length of heater hose (hold one end to your ear), or by a Mechanic's Stethoscope and carefully place it near various parts of the engine and components, this will help you to determine where it's from.
My suspicion is that it's a bearing, especially as it quiets as the Revs raise. Check the Alternator, Waterpump, Compressor, Oil Pump. But, do this very CAREFULLY - do not wear any loose clothing, watch, jewelry incl. neck chain(s). Hope this helps...
Happy Motoring!...Jim'99
Moostang 10-31-2005 09:08 AM
problem solved...
top pulley ( not sure which ) with three torx screws.... one was loose... a quick fix... to an annoying problem. relief!
