Old 11-23-2012, 01:16 PM   #1
jacabean's Avatar
metal in oil filter
Today was a nice New England day so I decided to change my oil (every 3000). I got 25% off some castrol 5w40 even better. When i cut the old filter open i found about a dozen good size metal shavings not the typical micro flakes. Should I be concerned ?
Old 11-23-2012, 01:29 PM   #2
Track rat
Topless's Avatar
Does it pick up with a magnet?
Has your IMS been updated?
Year, model, and mileage?
Reference for size (penny)?
Old 11-23-2012, 01:37 PM   #3
jacabean's Avatar
it's not magnetic , so i assume it's aluminum . The shavings are about 1 to 2 mm in size. I have never had anything that big show up in the filter.
Old 11-24-2012, 08:26 AM   #4
Newb
V-Rod's Avatar
Jacabean,
That does not look good. I will stay tuned into this thread as I am a new Boxster owner and I am learning everyday.
This IMS & RMS crap has got me paranoid. I do not mind fixing things that wear but not spontaneously a few hundred miles from home.
BTW, I am in MA as well. Central MA to be more specific.
V-Rod is offline   Reply With Quote
Old 11-24-2012, 09:55 AM   #5
Skrapmot's Avatar
They look like milling debris if they are not magnetic, probably not a destructing bearing. The black plasticy thing could be a piece of the chain guide/pad.
Wouldn't hurt to drop the sump plate and check for any larger pieces, but I personally wouldn't stress about it.
Old 11-24-2012, 12:54 PM   #6
jacabean's Avatar
i am not stressing over it . if the metal was magnetic i would . that is why i think 3000 mile oil changes are best for our cars . we can really keep an eye on what's going on in our internals. i must say i did panic a little when i first saw the shavings but after taking a closer look they are very small and few. i always see little plastic stuff and very fine metal flakes .
Old 11-24-2012, 01:51 PM   #7
Track rat
Topless's Avatar
A few tiny aluminum flakes... normal stuff for any engine. Ignore.
