Old 11-20-2012, 05:52 PM   #1
jrcui's Avatar
Tire size help
So, I found a set of 18"s (fronts are 7.5 x 18 et 50 and the rears are 10 x 18 et 65). I knew I need spaces for the rears so I bought some 20mm spacers that came with the extend bolts. I just got the wheels back from the painter and now I need to find the appropriate tires.
The PO had them on a Vanagon so the front tires have a lot of outer wear and the rears are mis-matched (Toyo and Michelin). The fronts were 225 40 18's and the rears were 265 35 18's.
Are the current tire sizes right for a 2000 Base or should I be using a different size? Trying to figure out the proper sizes so I can hunt for the best deals.
Thanks in advance!
jrcui is offline   Reply With Quote
Old 11-20-2012, 06:00 PM   #2
Johnny Danger's Avatar
Thanks in advance!
Those are the appropriate sizes.
Old 11-20-2012, 06:16 PM   #3
jrcui's Avatar
Thanks Mr. Danger!
Old 11-20-2012, 06:29 PM   #4
Keep in mind, that the boxster came fitted with 18x9 inch rear wheels. 996 platform vehicles had 18x10's. Still, a 265 tire will work fine. Just make sure that you bring the offset down to around +45 as you mentioned.
Old 11-20-2012, 06:53 PM   #5
jrcui's Avatar
Do you know if you have to zip tie anything back for clearance on the rears? I thought I saw that mentioned when I did a forum search.
Old 11-21-2012, 08:54 AM   #6
In your situation, it would be the wheel, not the tire, that would come into contact with the brake cable.
Old 11-21-2012, 08:51 AM   #7
HAUSIDMT's Avatar
I would, I have 275/35/18s on the rear, with evidence that the Parking brake cable has come into contact a few times.
2002 Boxster S with a few goodies, my 2nd Porsche.
1st was a 1966 912 hand me down from pops
HAUSIDMT is offline   Reply With Quote
