-   -   Spare key (http://986forum.com/forums/boxster-general-discussions/37889-spare-key.html)
Dgrange 10-29-2012 05:02 PM
Spare key
Hi all,
I have a 1997 Box and need a spare key, any ideas where to buy a blank? Would prefer with Porsche logo.
RandallNeighbour 10-29-2012 05:48 PM
You must buy a key head with a transponder coded for your car. And you must buy a blank.
Be careful buying key heads off eBay. If it doesn't have the original hang tag with a barcode on it so the dealer can program it or its not the correct part number, you're screwed.
I'd call sunset imports in Oregon and buy both. Your local dealer will program it for you and cut the blank for about $100.
Dgrange 10-29-2012 06:59 PM
With my car being a basic Boxster I didn't think the key had anything in it other than just the key. I open the car the old fashioned way with the lock in the door. Can I not just buy a black key and get it cut??
RandallNeighbour 10-29-2012 07:13 PM
I don't think so. Your key head has an anti-theft transponder in it even if I doesn't have an alarm system...
pk2 10-30-2012 12:41 PM
Its not the transponder "pill" in your key that has to match anything. The "pill" has doesn't matter, the immobilizer has to be programed to match the "pill" to work. Than you just need a key shaft carved to turn the tumblers.
The catch is, if you get a Key off of eBay (for instance), with a(indeed) working "pill" you're only part way home. Your immobilizer Box has to be able to be programed to except a new pill. It only has four slots for such a new pill/codes. If your car has lost soms keys and had new ones programed, you may be out of pill slots. You'll need a new imobilizer.
If you just want to open the door but not start it, that's fairly cheap. Not a bad thing to have around but won't start the car.
Regards, PK
Dgrange 10-30-2012 12:51 PM
So do I need to go to a main Porsche garage?
jcb986 10-30-2012 12:58 PM
Yes...call around and find what they charge. I can get a new one from a dealer here in Florida for $185, cut and programmed.
