-   -   Sun visor sticker removal- simplified (http://986forum.com/forums/boxster-general-discussions/37822-sun-visor-sticker-removal-simplified.html)
Slate 01 11-11-2014 06:06 PM
Acetone removes those labels very easily. Much better having those warning billboards removed.
ZzzTime 08-01-2019 09:50 AM
Visor warning label residue optional solution.
I purchased a '98 986 in May and found the back side of the visors to have the airbag warning labels cracking and peeling. The stickers came off in pieces, leaving an adhesive residue. I tried using isopropyl alcohol, Goo Gone, Magic Eraser, etc. but the residue seemed embedded in the textured vinyl. A friend and Porsche enthusiast had told me about a leather refinisher (found it on Amazon along with a pre-treatment cleaner) for a slightly warn area on the edge of the driver's seat. The leather boot on the manual shift also had areas of wear. The refinisher worked awesome here, so I thought why not try it on the visors. I used a blue shop paper towel to add a "textured" look to the visor, this step is probably not necessary however. It just ended up removing some of the refinisher, requiring a second coat. Hope this helps someone. Good luck!http://986forum.com/forums/uploads02...1564677900.jpg
http://986forum.com/forums/uploads02...1564677938.jpg
http://986forum.com/forums/uploads02...1564678041.jpg
http://986forum.com/forums/uploads02...1564678083.jpghttp://986forum.com/forums/uploads02...1564678155.jpg
http://986forum.com/forums/uploads02...1564678184.jpg
Starter986 08-01-2019 10:20 AM
That looks great!
