-   -   Headlight switch won't stay out to keep fog lights on (http://986forum.com/forums/boxster-general-discussions/37672-headlight-switch-wont-stay-out-keep-fog-lights.html)
BrandonJames89 10-12-2012 12:32 AM
Last night I was heading out to pick up a friend and noticed that my headlight switch felt a little off when I engaged the fog lights. It didn't fully click into position and felt like it would only go halfway between on and off. After I picked them up and tried turning them on again the switched would pull out all the way and turn on the lights but when I release it the switch just snaps back into the off position with the spring. Seems like whatever locks the switch in the fog light on position has failed.
I searched the forum and saw a bunch of problems with headlight switches but all my lights function properly. Has anyone else experienced this issue? Just need to know if it can be fixed or if I have to replace the switch.
schnellman 10-12-2012 04:40 AM
Replace the switch. Quick, easy way to eliminate the problem.
BrandonJames89 10-12-2012 01:27 PM
Would the locking mechanism have anything to do with the switch that you actually see and grab or is it in the mechanical switch behind the dash?
schnellman 10-12-2012 05:49 PM
The mechanical parts of the switch are no doubt shot.
