Old 09-23-2005, 08:10 PM   #1
Installing onto top of Engine
I have sat with my new subwoofer for 2 weeks now. I love it behind my seat. It is sitting on top of the space above the engine. I need to mount it with the kit the speaker came with. Can I screw it right into the carpet ontop of the engine. What is underneath that. Is there any wood. Does anyone have a better suggestion of how to mount the speaker so it does not shift and stay put incase I am in a accident. If not the speaker might catapult into the back of my head or out into the air if the top is down.
thanks
Joji is offline   Reply With Quote
Old 09-23-2005, 08:32 PM   #2
bmussatti
Posts: n/a
I don't think there is much wood in your car dude! It's a freaking Porsche, not an ark!
Old 09-23-2005, 09:25 PM   #3
What you're looking to do is doable. Just put the top in the Service position and remove the Engine cover. Then I suspect that some good Nuts & Bolts, along with 2" Fender Washers would do the trick. Hope this helps...
Happy Motoring!...Jim'99
Old 09-23-2005, 09:47 PM   #4
tqtran's Avatar
You got a Porsche, and its made to go fast. Its not a "subs'n dubs" ride.
tqtran is offline   Reply With Quote
Old 09-24-2005, 06:02 PM   #5
Hey maybe you could try to velcro it to the carpet! That way you will not have to screw anything into your car.
1999 Arctic Silver Metallic/Graphite Grey top/ tiptronic transmission
nautiquelfe is offline   Reply With Quote
Old 09-24-2005, 10:52 PM   #6
I though of using velcro. But I am still concerned if I am in a accident going even 40mphs that the sub will end up through the back of my head. I would like to brace it down
Old 09-25-2005, 10:45 AM   #7
You should be able to bolt it to the engine cover as said, useing a large area washer(fender washer).
I'm curious, with the sub back their you can put the top up and down?
Richard
my89_928gt is offline   Reply With Quote
Old 09-26-2005, 01:20 PM   #8
TriGem2k's Avatar
Send a message via AIM to TriGem2k
How big are the subs? and how did u get it to fit in there? Does the top still go up and down?
TriGem2k is offline   Reply With Quote
Old 09-26-2005, 03:30 PM   #9
Rouser's Avatar
THANK YOU!
Put the sub in the SUV, and drop the top in the Box, You can't gangsta lean & shift at the same time.
Rouser!
Rouser is offline   Reply With Quote
