09-21-2005, 08:50 AM
Another question about 18" wheels
I want 18" wheels for my 987S (on order), for ride comfort and handling. I like the look of the 18" Carrera III wheels, but I understand they don't fit on a Boxster.
It has been slow to dawn on me that 18" 996 Carrera 5-Spoke wheels look nearly the same and were optional on the 2003 Boxster S. Those wheels come in 8" and 9" widths -- just the same as the 2005/2006 18" Boxster S wheels.
You can see the wheel choices here: Wheel Enhancement
Is there any reason why I shouldn't put 18" 996 Carrera 5-spoke wheels on my 987S?
09-21-2005, 12:11 PM
Below is information that I got from Wheel Enhancement. Any comments on the info they have provided? Is there any issue created by these differing offsets, or with the use of spacers on the rear wheels only?
According to Wheel Enhancement:
The wheels on the 2006 Boxster S have the following offsets:
8x18" 57mm
9x18" 43mm
The 2002 996 Carrera 5-spoke wheels have the following offsets:
8x18" 50mm
9x18" 52mm
Using the 8x18" 2002 wheel with a 7mm more aggressive offset on the front is not a problem, the wheel will be well within the fender on the car. The rear 9x18" 2002 wheel sits too far inboard without using a spacer, affecting the handling as well as having a negative affect on the appearance. Using a 17mm Porsche Factory wheel spacer (and silver anodized lug nuts) will bring the rear wheel out 8mm further than the stock wheel, compatible with the front wheel's position.
09-21-2005, 12:38 PM
20s on a 987
If i had a 987, id put 20s straight up. though this is a 986 forum, id put 19s on my 986. 987 is suppose to be more bold and muscular as opposed to my skinny boxster that will probably fit (well safely) 19s very nicely. 20s on a new boxster....
see u
09-21-2005, 01:03 PM
Depends if you're interested in ride, performance, or bling. Bigger wheels are heavier, and the tires that go on them stiffer. Performance can be a toss-up if the widths aren't getting bigger. Ride will definately suffer.
09-21-2005, 07:56 PM
Agreed. Add to that, an increase in wheel size increases your Rotational Inertia which can impede acceleration and lengthen braking distances. Also, the most significant thing about the weight increase you mention is that it is Unsprung Weight, very undesireable and something which most Enthusiasts work hard to minimize.
Bigger wheels are pretty much totally about the bling. The performance gains are touted way out of proportion to what they really are in Real World Terms. For the Boxster, the 18" is the best compromise and the biggest you should go. These will fill out the wheel wells nicely without too many negatives.
I know that Porsche sells 19 inchers, but this is totally due to Market Demand and a Sales opportunity. I guarantee they are not running on 19's when they gather their performance data.
Happy Motoring!...Jim'99
09-21-2005, 08:04 PM
18s on the Box rule!
09-21-2005, 08:23 PM
Yep,
Got 18 Turbos on mine! They look great, can't imagine how puny a 16" must look.
09-22-2005, 01:51 PM
Well
I ve been told that when i go from a 17 to a 19, i will have less rubber, way lighter rim, and wider tire...so really performance shouldnt be an issue. yes i am under the impression that each inch bigger that i go from the 17 will decrease my 0-60 speed by a second and this on a boxster is really really bad. but someone here corrected this and had a valid point...less rubber lighter rim wider tire...performance is not an issue....for 18s to look really nice, the car has to be dropped 2 inches. 19s drop one inch...sick
no performance issues
check my second pic, this is what a porsche should look like
see u
09-22-2005, 03:20 PM
see u
You have also been told that these things are not true, you simply choose not to believe it.
09-22-2005, 03:53 PM
Is that you Morpheus?
1997 Honda Accord | V6
2004 BMW 330i | ZHP | SOLD
http://kryzak.tumblr.com
09-22-2005, 06:40 PM
I ate the red pill..and ended up with the 18" Carrera
BTW They have almost the same wheel for the 987 in the brochure.
2004 Boxster - Carmon Red/ Black-SOLD
18" Carrera Lt, Painted to match roll bars, PnP Rear Speakers, Sports Tailpipe
2004 Tonka Truck H2
05 S - looking...
09-22-2005, 11:12 PM
Don't get me wrong, if you want the bigger wheels just for the aesthetics, more power to you! It's your car and your money. Go for it!
But, you're kidding yourself if you think there's a Real World performance benefit. In truth, there are some; if you are at 70MPH+ on a tight road course. Absent this, the negatives outweigh the gains.
I also concede that aesthetics are important, just not all-important, meaning that some compromise should be made. I have 18" Turbos on my Boxster and they look great. I believe and have read of many others that the 18's are the best compromise. Good Luck!
