Old 09-07-2012, 01:13 PM   #1
mountainman's Avatar
engine and radiator cooling fans
anyone know what controls when the engine cooling fan comes on and off. I am assuming the radiator fans are controled by engine temp thru a relay. wonder if the engine cooling fan works similarly.
Old 09-07-2012, 02:43 PM   #2
The cooling fans are controlled by the DME software; the settings cannot be changed.
Old 09-07-2012, 06:30 PM   #3
oc-boxster's Avatar
Does the engine fan come on when you first start driving the car I swear mine runs for a minute or two when I first drive away from my house when it's cold?
oc-boxster is offline   Reply With Quote
Old 09-08-2012, 03:25 AM   #4
My engine fan does come on at startup also.
Old 09-08-2012, 05:56 AM   #5
Are you sure you are not hearing the secondary air system, which runs for a short time at startup?
