Old 08-29-2012, 08:34 AM   #1
Spin lock East to remove?
I found a hard top close (~300miles)
I will drive there and install it on my 2000 Boxster S. Is it hard to take off the spin lock from the previous owner Boxster to install on mine? What size torx will I need?
Chris
wawa is offline   Reply With Quote
Old 08-29-2012, 09:40 AM   #2
bar10dah's Avatar
If you're facing north, you can spin the locks to the east to tighten. If you want to loosen, turn the car around so it faces the south. Then you can spin them to the east to remove.
Okay, I couldn't resist.
bar10dah is offline   Reply With Quote
Old 08-29-2012, 09:42 AM   #3
bar10dah's Avatar
Pelican Technical Article: Installing the Boxster Hardtop and Installation Kit - 986 / 987
Old 08-29-2012, 09:49 AM   #4
Haha lol. I've try to Edit the title but it's not possible.
Chris
Old 08-29-2012, 02:45 PM   #5
boxster6354's Avatar
LMAO!
Yes it is easy as only one set screw holding each in, but it is very easy to drop screw, either a strong magnetic screw driver or the slider type socket (slides over screw as you back it out) for the screw driver bit works well too.
also two screws on each side to take off carpet to get access to the screw, the Pelican link provided above will show where they are.
boxster6354 is offline   Reply With Quote
