Old 08-25-2012, 09:38 PM   #1
jrcui's Avatar
23mm spacers
Porsche Boxster 23mm Wheel Spacers | eBay
Does anyone have any experience with these? They come with the extended bolts and claim to be USA made. Looking at buying a set of 18" twists that have the 65 rear offset so I know I will need spacers.
Thanks in advance.
jrcui is offline   Reply With Quote
Old 08-26-2012, 05:03 AM   #2
Johnny Danger's Avatar
They appear to be correct .
Old 08-26-2012, 09:19 AM   #3
jrcui's Avatar
Thanks JD. I was just curious about the build quality since they are almost half the price of the H&Rs when you include the bolts.
Old 08-26-2012, 01:39 PM   #4
They look to be well made. Keep in mind, that one is paying for the name when it comes to brands like H&R. Good deals can often be found in different places and with other brands . Just make sure that you're given the correct length lug bolts; especially for the rears .
Old 08-26-2012, 04:00 PM   #5
jacabean's Avatar
I have been looking at these also , even in the same size . i think they will work fine.
Old 08-26-2012, 04:31 PM   #6
pk2
If you keep your eyes open, you can find 25mm 944 spacers on ebay. I got a pair for $16. Still had to get new studs but it was all a lot less on a whole.
Regards, PK
http://img87.imageshack.us/img87/163...58x6ir4.th.jpg
99 Supercharged 2.5L
pk2 is offline   Reply With Quote
Old 08-30-2012, 08:53 PM   #7
jrcui's Avatar
Bought a set of 18" twists that have the 65 offset on the rears for $350. I think the fronts will be fine, so now the hunt for the 23mm spacers begins along with a set of tires. The PO ran the wheels on his Vanagon so the front tires have bad inner wear (and the one of the rear tires is a mismatch).
The next question after the spacers is what's the best tire sizes for the fronts and rears.:dance:
