Old 08-16-2012, 12:28 PM   #1
tonycarreon's Avatar
Oil Change Special @ Advance
just an FYI for castrol syntec fans, advance auto parts is doing an oil change special with castrol syntec as the oil.
i had to call to get the "special" price since they don't have an oil filter for the boxster in the brand that is part of the special. so instead they discounted the filter for the boxster.
before discount, price was 105.90, after discount it was $59.96 + tax
first 5 qts were $4.49/ea, qts 6-9 were 6.74/ea. filter was $10.59
Old 08-16-2012, 02:31 PM   #2
l3m
l3m's Avatar
Thanks for the tip. I need to get some for my next oil change.
The Advance store near my house had the same deal earlier this year. A free oil filter for every 5 qts of Castrol. They gave me two Purolator L25316 filters for free. What's odd is I went to another Advance store prior to that and they had a Mobil1 special going on but didn't have 10 quarts in stock so went to the 2nd store and they had a Castrol deal going on.
'01 S
l3m is offline   Reply With Quote
Old 08-16-2012, 03:16 PM   #3
Not bad, I get Castol or Mobil 1 for about $5.20 a qt at walmart. Hengst filters I get online at $13.
shadrach74 is offline   Reply With Quote
Old 08-16-2012, 03:16 PM   #4
Tony,
Which Castrol do you use?
I have never used the Castrol before but I want to try.
Thanks in advance.
mikehkang is offline   Reply With Quote
Old 08-16-2012, 04:24 PM   #5
the formerly known as "castrol syntec", now known as "castrol edge with syntec power technology"
usually 5w40. trying 5w50 this time.
i've used royal purple, mobil 1 and castrol and the castrol seems to do a little better on start up with the clatter.
Old 08-16-2012, 04:52 PM   #6
Tony,
Thanks for the prompt reply.
However, you must have some regional special deal.
I am in NJ and I can't replicate the prices you mentioned.
Old 08-16-2012, 06:59 PM   #7
Tony, You ought to read this when you have a minute.
http://www.bobistheoilguy.com/motor-oil-109/
Old 08-16-2012, 06:13 PM   #8
you have to call their customer service since the special is 5 qts + a bosch filter, and there's no boxster filter that's part of the deal.
if you have another car and want to use their filter, just add the oil, then get the bosch distance plus filter for your other car.
the cart will then update with the discounts. the filter goes from $13.49 down to $8.57. the 9 qts of oil go down from $80.91 to $51.39 ($5.71/qt)
i tried it with a local newark, nj store and it still works.
Old 08-16-2012, 07:20 PM   #9
hah, a minute. bob's site takes way more than a minute. makes my head spin and i feel dumber after reading.
anyway, i think the point you're trying to make is that at start up, a lower weight oil will flow better and provide more lubrication. point taken, but not in my experience. 0w are meant for cold ambient temps and i don't drive the car when it's under 50º. if the point is that it will be harder for the 50 weight to flow at operating temp than the 40, point taken and i'm aware of that. that's why this change is a "try".
if i missed the point, please feel free to make it. i can be thick (pun intended) sometimes.
Old 08-17-2012, 05:45 AM   #10
I think you sort of got the point. I do not know the specific mileage of your car so you may be right on the money... However, the point I was trying to make is that the high number in a multiweight oil effect how it flows at any temp below operating temp.
Taken from Bob's graph (numbers are not exact)
Oil type_____________Thickness at 75df
0W-20_________________40
0W-30_________________50
0W-40_________________60
A thickness of 40 is still less than ideal for startup, but it's far better than 60. I think the point that Bob was making is that there is no utility in running a heavier weight (for the high number) multigrade oil unless your engine is not reaching ideal oil pressure (10lbs per 1000rpm). If pressures are are higer than that, you're not really doing yourself any favors and could be getting less flow even with the higher pressure in some cases.
You mentioned that your experience with higher weight oils is different. Could you elaborate?
Old 08-17-2012, 06:02 AM   #11
anecdotal evidence, and a single point on a graph do not make for good statistics, but i've found, for my engine / car, that the 0w40 (admittedly only used M1 in that weight) produces more chain noise at start up than when i move to 10w (even when it was M1).
also, just checked the old bottles and i've been running 10w, not the 5w so we'll see if that does anything.
and the mileage is at 102k
Old 08-18-2012, 06:17 AM   #12
Hello Tony,
Thank you.
I picked up 4 sets (20 qts and 4 filters!) for 32.98 each before tax.
I don't know if I can return the filters but if not, I can use them on my Outback and Sienna.
Now the bad news.
On the way home, the battery light came on.
The alternator is not charging.
I know you replaced yours. How was that like? There seems to be an option to replace the voltage regulator(!?) was that an option for you?
Old 08-18-2012, 08:06 AM   #13
Homeboy981
Homeboy981's Avatar
Hi Guys,
Bad news for us in Texas, correct me if I'm wrong, but this "deal" with Castrol thru Advance Auto, is NOT available here….and they don't ship at this price.
BTW the price here at Walmart is closer to $8 a qt.
So the Castrol deal would be great IF we were there. Anybody coming to Dallas? Can you pick up some oil on the way? he-he
Old 08-18-2012, 09:59 AM   #14
Originally Posted by mikehkang View Post
Hello Tony,
Thank you.
Now the bad news.
i was driving on I30 from Dallas to Texarkana, on my way home to MD when the battery light came on. closest town (Commerce, coincidentally where I went to college) was 15-20 miles away and i got the car there. stopped at O'Reilly and they confirmed alternator was not working. my options were to mail-order the regulator, and spend a few extra nights there and hope that was truely the issue, or buy an alternator from OR which would arrive the next morning. short story i spent the morning in the texas sun in a hotel parking lot switching the alternator i purchased from OR. thankfully i got a few necessary tools from walmart next door. not something i want to do again in the same situation. if i were at home, i probably would have ordered the regulator and tried that first. the actual labor was't too bad, just not fun when it's so hot outside. the bolts were pretty tight, and the alternator was a pretty tight fit. either way, the alternator must come out, if i remember correctly, since the VR is on the backside.
Old 08-18-2012, 02:29 PM   #15
if the ambient temp is under 50, and you're not putting the engine through much i could almost get behind a 30 weight oil. but still, it's going to break down too quickly under the heat and pressure once the engine is up to temp.
not to mention porsche's recommended oil weights are 0w-40, 5w-40 and 5w-50
Old 08-19-2012, 07:38 AM   #16
thanks homeboy. i drive to dallas a few times a year. it seems every long distance trip ends up with something taking a crap away from home - alternator, motor mount, water pump, etc.
maybe just a general dallas meetup would be fun. someone - timothy? i cant remember - said there was one that occurs at the fuddruckers on 75 on one of my trips. haven't had a chance to stop at one yet.
btw, i'll check before my next trip and see if anything's on sale. i usually have the rear trunk empty.
Old 09-05-2012, 04:29 PM   #17
New to this porsche stuff, bought my first Porsche only 4 weeks ago as project, and i have a problem with oil pressure. !!!!Boxster 2.5 1998 90K miles. will dump the oil out of her, replaced filter and was going to refill with 5w-40w ? The trouble ive got is at start up all good.. as she warms up oil pressure disapears after about 5 minutes on tick over and puts on oil warning light, i have checked this with an old external presure gauge and drops to 5Lb psi when warm .. 22Lb psi when starting from cold and zooms up to 70psi + when revved Have already checked the pump and both scaenger pumps and all fine.. Cant believe just fresh oil will resolve this pressure issue . ANYONE GOT ANY IDEA`S what next ?
Andyoh is offline   Reply With Quote
Old 09-05-2012, 05:55 PM   #18
Spinnaker's Avatar
The next thing I would check is the oil pump pressure regulator spring and plunger. There were some older posts about these sticking.
