Old 08-11-2012, 11:26 AM   #1
mcomet's Avatar
Side marker lights Q
So I did my bumper removal/radiator clean this morning. Went ok tho I broke two lower rivets in the wheel well...need to order some replacements...
Anyhow..
I noticed when done my side marker lights weren't working as "turn signal". I checked with a multi-meter and they are getting a up/down in voltage. When I turn my "dims" lights on then they light solid... and only my front right headlight illums. When I turn my brights on, then both headlights and the side lights are on. My brights also work.
So I guess Q is...
1. I assume my side marker lights should blink as emergency and turn signal yes?
2. I assume my dim light not working driver side means something else is wrong?
thoughts?
thanks,
comet
Michael Comet - www.comet-cartoons.com
2014 Guards Red Cayman S - PSE - PASM - 20"CC - INFTMT - CONV - etc..etc...
SOLD - 2003 Speed Yellow Porsche Boxster S - LNE IMS - Klisstle Rollbar Cover
mcomet is offline   Reply With Quote
Old 08-11-2012, 11:28 AM   #2
That's correct, they're not turn signals, although you can hack it with a relay to turn them into signals.
Old 08-11-2012, 11:50 AM   #3
mcomet's Avatar
Wow ok I thought they were turn signals...so sounds like that is good.
What about the white "dims" only being on the passenger side?
thanks!
