Old 07-23-2012, 08:04 AM   #1
Check engine light flashing only over 5500-6000 rpm
Hi everyone. I have a 2000 Porsche Boxster 5 spd and just replaced the engine with a used very low mileage engine. I replaced the the flywheel, clutch and most of the parts from the new engine were installed. The problem I'm having is that when the car goes over 55-6000 rpm the check engine light starts to flash, then I let off the gas and it flashes for a bit then goes away. This problem was happening with the old motor as well. The only thing that was salvaged from the old engine were a few hoses and wiring harness because the new engine wouldn't match up with the ECU. Anyone know what's causing this to happen? Thanks.
2door2nv is offline   Reply With Quote
Old 07-23-2012, 08:13 AM   #2
You need to check the codes with a Durametric or other diagnostic tool. Then post the results.
Current car
2000 Boxster 2.7l red/black
Previous cars
1973 Opel Manta
1969(?) Fiat 850 Convertible
1979 Lancia Beta Coupe
1981 Alfa Romeo GTV 6
1985 Alfa Romeo Graduate
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1989 (?) Alfa Romeo Milano
1993 Saab 9000
