Old 07-09-2012, 04:34 PM   #1
vitaminC's Avatar
speakers or HU, or both?
Recently it appears that the speakers in my '03S have died. A while back there was no sound at all from the radio, and now I get sound but it's got a lovely crackle to it. It is not affected by source or balance, and is present at all volume levels. So I presume the speakers are shot and maybe the HU, too?
Don't really want to replace/upgrade the stereo, as I've spent enough recently on other maint issues.
I love driving this car, but the semi-weekly issues are really getting annoying!
'03 986S
vitaminC is offline   Reply With Quote
Old 07-09-2012, 05:45 PM   #2
Crackling at all volumes is most likely the hu, though it wouldn't hurt to replace both. If you're on a budget, start with the hu. You can get a pretty decent Sony or Pioneer for right at $100. I'm 90% sure that a new one will fix your issue.
Old 07-09-2012, 06:42 PM   #3
Gforrest2's Avatar
Do a little research before changing out your radio. I have an '03 with the CDR23 HU and the Becker BE6600 amp. Something died a couple of months ago (I think it's the amp) but due to the MOST (fiber optic) bus and 2 ohm speakers, replacing the head unit is not as simple as it seems.
Glen
Gforrest2 is offline   Reply With Quote
Old 07-09-2012, 06:49 PM   #4
I can't speak for the stock speakers as I never had them, but my Infinity speakers sound great direct wired to the Sony 52w x 4 HU! No amp needed.
Only 2 ohm, eh? I am so not impressed with the stock stereo gear, from what I've read.
Old 07-09-2012, 07:11 PM   #5
vitaminC's Avatar
I was fine with the sound quality, as I don't really expect (or need) greatness from the stereo in a convertible. It's more just the annoyance of having one more thing that needs fixing, and right before I'm set to take a trip in the car this weekend. Guess I'll pack my earbuds instead!
'03 986S
Old 07-09-2012, 07:53 PM   #6
Joel-Box-ster's Avatar
Resistance
If you can take out the speakers and measure the Ohm resistance it should read between 2-6 ohms and the speakers are fine.
2K Boxster White/Grey Int./Hardtop/TIP
Joel-Box-ster is offline   Reply With Quote
Old 07-10-2012, 04:25 PM   #7
vitaminC's Avatar
Oddly enough, this morning everything sounded fine. With that, I presume we can rule out the speakers being the problem and point instead to either the HU or a loose connection somewhere.
'03 986S
