Old 07-02-2012, 02:31 PM   #1
Rim fitment question
I was thinking about buying some 997 turbo rims for my 2001 Boxster and didn't know if they would fit properly?
Wheels diameter: 18 Inch
Wheels Width: 8.0 Front and 10.0 Rear
Bolt pattern: 5x130
Offsets: ET.50 Front & ET.65 Rear
Thanks for the help!
asexton is offline   Reply With Quote
Old 07-02-2012, 03:17 PM   #2
Johnny Danger's Avatar
Depending on what size tire you'll be using, ideally the rear offset should be reduced to +45 . The fronts will fit, however, if you're looking for a more aggressive "stance" I recommended bringing the offset down to around +40 or so . Again, it depends on what size tire you'll be using .
Old 07-02-2012, 03:38 PM   #3
I have 265-35-18 tires for the rear and 225-40-18 for the front.
Old 07-02-2012, 05:46 PM   #4
Then I would follow my recommendation .
Old 07-03-2012, 09:45 AM   #5
Thanks for the info!
