-   -   Exchange 2 Ohm speakers to 4 Ohm ? (http://986forum.com/forums/boxster-general-discussions/35954-exchange-2-ohm-speakers-4-ohm.html)
spongebob 06-17-2012 07:12 AM
I have so far done the three first recommended steps on my way to a decent sound in my Boxster
Installed is the original 4 channel Haes amp plus:
-New front speakers
-Installed PNP rear speaker kit
-New 6" door speakers
But sound is still more or less crap and as soon as I set Bass level above +2 there is severe distortion. Think it is the door speakers that can not handle the low end range. I have tried a few different speakers and today I have those installed:
SXT6 « InPhase Audio
They are 4 Ohm instead of the replaced 2 Ohm original ones. Is this causing the problem and should I look for a set with lower impedance?
Joel-Box-ster 06-17-2012 09:51 AM
Its ok to use 4 ohms speakers, you need higher wattage door speakers the one you have right cant handle the output of your amp.
spongebob 06-17-2012 10:18 AM
Sure? manual says 240w max, The Haes is on 4x40 only
Joel-Box-ster 06-17-2012 10:47 AM
Try using a low pass filter capacitor inline with the door speakers that might solve the distorsion if not just keep the bass level to a minimum.
