Old 06-07-2012, 12:02 PM   #1
986S Brakes on a 986
I've had some people answer back, but they've all been different. Thought I'd go public.
There are always people parting with their 986S Brembo drilled rotors and calipers for cheap. Seeing as my brakes are getting worn out, I was wondering if the 986S brakes would fit on my Boxster non-S. I consulted a mechanic and he said we'd have to see if the 'knee' or 'knuckle' was the same size. I was wondering if anyone here knew.
What would I need to purchase, aside from the rotors and calipers?
Old 06-07-2012, 01:19 PM   #2
Fronts are a bolt on swap; rears are vastly more complicated as the e-brake is entirely different. In order to get the rears on, you need to swap out the rear carriers for the “S” units and use “S” e-brakes; all of which is very expensive.
Old 06-07-2012, 02:03 PM   #3
The stock base brakes are pretty atomic. On the track they perform very well. The last DE event I did, the brakes were absolutely flawless with Mintex pads(cheapest OEM pad). No fade, no shudder, and I was late braking with the best of them. For the street, the stock brakes are way more than you will ever need.
Current car
2000 Boxster 2.7l red/black
Previous cars
1973 Opel Manta
1969(?) Fiat 850 Convertible
1979 Lancia Beta Coupe
1981 Alfa Romeo GTV 6
1985 Alfa Romeo Graduate
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1989 (?) Alfa Romeo Milano
1993 Saab 9000
Old 06-07-2012, 02:32 PM   #4
Topless's Avatar
Yep, a direct bolt-on with no issues in the front. I prefer the base front brakes though.
Old 06-07-2012, 04:37 PM   #5
What other options do I have if I wanted to go for the large drilled rotors look?
Old 06-07-2012, 05:37 PM   #6
Spinnaker's Avatar
There are lots of manufacturers that make cross drill rotors for the base Boxster. Just do a search on some parts sites.
I don't think you will see the difference in diameter, since it is only ¾". Paint your calipers red and get the cross drilled rotors. Save yourself a lot of time and money. I doubt if anyone could tell the difference unless they took the wheels off and measured the rotors.
Old 06-08-2012, 03:48 PM   #7
Would these fit my current non-S calipers?
Front Left:
Pelican Parts - Product Information: 996-351-406-02-M359
Front Right:
Pelican Parts - Product Information: 996-351-405-02-M359
Rear Right/Left:
Pelican Parts - Product Information: 986-352-401-04-M867
They're Zimmermann drilled rotors. Does anybody know about the brand?
I'll be honest, I'm not trying to lessen track times. My brakes are getting worn out and I need new ones, so I may as well get the drilled rotors and painted calipers for the bling value.
Old 06-08-2012, 04:14 PM   #8
Topless's Avatar
Front Left:
Front Right:
Rear Right/Left:
Nope, but these will:
Pelican Parts - Product Information: 986-351-401-05-M867
Or these:
1997-2004 Porsche Boxster Brake Disc – Centric 126.37030SL - Front, Driver Side, Centric Power Slot, Slotted
Old 06-08-2012, 04:41 PM   #9
S brakes fill the wheel better especially when you have 18"s on.
I did a complete front S calipers DIY rebuild with red powder coat. Also bought a set of 2-piece floating dimpled rotors. Yes it was costly but I have OCD. Don't all Porsche owners have OCD?
adult image hosting
Old 06-08-2012, 04:43 PM   #10
Interesting, why so?
Old 06-08-2012, 06:49 PM   #11
What about the rears I listed there?
Old 06-08-2012, 09:55 PM   #12
Topless's Avatar
Lighter unsprung/rotational weight, less expensive consumables, never ever have brake overheat issues (even heavy track days in 106F air temps), front base brakes can easily overpower 255 R-comp rubber up front and go into ABS, don't care for the cross-drilled look. Due to my tire choices, brake bias is already pretty far forward. Adding "S" brakes would move it further forward putting the car on it's nose under heavy braking. This would unsettle the car and lengthen braking distances. The opposite of what I want. I see no benefit to "S" brakes on my car at this point.
If I squeezed a 450hp Raby 4.2L motor in there I would generate a lot more brake heat at the track. Then maybe "S" brakes would be needed to help manage heat. Maybe not.
Old 06-08-2012, 09:58 PM   #13
Topless's Avatar
Yep these will fit:
Old 06-09-2012, 11:08 AM   #14
Since the fronts are plug and play and fill the wheel better, I think I'm just going to replace the front brakes with S brakes, get that Pelican rear rotor, and paint the rear caliper red... It seems to be my most cost efficient aesthetic upgrade.
Thoughts?
Old 06-10-2012, 02:45 PM   #15
Don't know if the car is for the track only or what but if it is DON't get drilled rotors...strictly bling...get either slotted or solid rotors...
Drilled rotors are more prone to cracking under hard usage.
Eddie
PCA National Certified Instructor
Andiamo Motorsports
1989 944 S2 R - Stock except.....
2003 Boxster S ( Euro delivery ! )
1990 944 S2 sold
sponsored by PDandM.com, General Contractors.
Building the Highest Performance Homes in the SML area.
smlporsche is offline   Reply With Quote
Old 06-10-2012, 02:54 PM   #16
Yea, I'm mostly going for bling value.
Thanks for all your input guys. I think I've concluded with going for front S Calipers and rotors, and the Zimmerman drilled rears with painted calipers.
That should work, yes?
