Old 05-21-2012, 06:10 AM   #1
Key Ignition Beeping-Stuck
When I pull my key out of the ignition, It still beeps as if it thinks I left the key in there.
When I try to put my key back in, I can't. It is as if something is in the way. I wiggle it around for a while until the beeping stops or until I get the key inside.
00 2.7 5SPD MT
ProjectM96 is offline   Reply With Quote
Old 05-21-2012, 06:19 AM   #2
igniton switch bad... likely just electrical portion. Part < $10 if bought online (auto haus az dot com) or <$50 if bought locally at Audi or VW dealer.
Be careful b/c battery drain will occur very quickly until replaced.
Here's a DIY link courtesy of Pedro
Good luck
Old 05-21-2012, 06:28 AM   #3
Thanks. I will try it.
00 2.7 5SPD MT
Old 03-11-2013, 03:47 PM   #4
I had a difficult time turning the ignition key, so i replaced the steering lock assembly and the rear electrical portion. The only part transferred was the piece the key goes into. Now it beeps as described in this post. Has anyone else had this misfortune?
I did have to take a hacksaw to the old aluminum piece to get the old lock out. I hope I didn't break the lock.
dbeesley1 is offline   Reply With Quote
