-   -   Half the LEDs out in aftermarket 3rd brake light (http://986forum.com/forums/boxster-general-discussions/35372-half-leds-out-aftermarket-3rd-brake-light.html)
Gforrest2 05-07-2012 08:10 PM
Anyone have an issue with those aftermarket LED 3rd brakelights? One half of mine has gone out. I don't think the LEDs are burned out, must be some failed electrical connection. I'm wondering if it's worth cutting apart to troubleshoot or if it's even repairable.
dghii 05-07-2012 08:56 PM
Sound like you have nothing to loose and it does sound like you may have a bad connection. Easy enough to check if you have a voltmeter.
smagerstein 05-08-2012 12:30 PM
Hi
From the first moment I installed a smoked led 3rd light they didn't work properly. The tech at my p dealer switched the polarity on the connector and all was fixed. He said he had seen this many times. Worked perfectly now for 6 months.
