Old 05-04-2012, 03:10 PM   #1
What is the standard running temp of your boxster?
As it is right now mine is running at about 190-200 Fahrenheit, idk if it's normal or not as it seems a little high for a Porsche, i could be wrong. Let me know what your car runs at.
BMP37 is offline   Reply With Quote
Old 05-04-2012, 03:44 PM   #2
DFW02S's Avatar
Same as yours.
DFW02S is offline   Reply With Quote
Old 05-04-2012, 04:14 PM   #3
gomarlins3's Avatar
Needle goes right through the "8" on the "180" in my 1998.
gomarlins3 is offline   Reply With Quote
Old 05-04-2012, 04:46 PM   #4
Moderator
Post Deleted
Old 05-04-2012, 05:07 PM   #5
How do you know thats the temp? Have you checked it with Durametric or an obd scanner? You can't estimate based on the guage.
Current car
2000 Boxster 2.7l red/black
Previous cars
1973 Opel Manta
1969(?) Fiat 850 Convertible
1979 Lancia Beta Coupe
1981 Alfa Romeo GTV 6
1985 Alfa Romeo Graduate
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1989 (?) Alfa Romeo Milano
1993 Saab 9000
Old 05-04-2012, 05:11 PM   #6
Moderator
Mine goes from 180-200. Has never been past 212 on the gauge though surprisingly.
Old 05-04-2012, 05:44 PM   #7
ckkrause's Avatar
About 175F in a '98... but I have the lower temp thermostat and added the 3rd radiator.......
-CKKrause
'11 F250 TD-Tow
'00 M5- DD
'67 912-Future Vintage Racer
'98 Boxster-SpecBox Racer
ckkrause is offline   Reply With Quote
Old 05-04-2012, 06:27 PM   #8
my 06 S goes to 175 within 5 minutes of start up and I've never seen it go higher
RobbieKnobbie is offline   Reply With Quote
Old 05-04-2012, 06:47 PM   #9
Now a suggestion to everyone: Plug in a scanner with PID capability and compare the actual coolant temps to what it says on the dash. You just might be surprised...............
Old 05-04-2012, 06:50 PM   #10
DFW02S's Avatar
Yup, measured temp was +15 to 20 on the dash reading.
Durametric and Autoenginuity scan tools were 3 degrees different.
Old 05-04-2012, 09:00 PM   #11
Joel-Box-ster's Avatar
Mine is 3mm off the 180 mark while cruising and in between 180 and 250 while waiting in traffic light. OBD scanner is an accurate way to check the water temp.
2K Boxster White/Grey Int./Hardtop/TIP
Joel-Box-ster is offline   Reply With Quote
Old 05-04-2012, 10:30 PM   #12
Read on the AC display I have 78C which is 172 F on the highway. This is the same temp as seen with a Durametric tool.
In stop and go traffic it shows up to 100C ( 212F)
This is with a low temp thermostat.
Until MY 2000 (at least) it is possible to use the AC hack to get some of the OBD info
Boxster AC Hack - 986 Series (Boxster, Boxster S) - RennTech.org Forums
spongebob is offline   Reply With Quote
Old 05-05-2012, 02:09 AM   #13
2005, Tiptronic
Snowman's Avatar
At least 5 minutes to reach it, I've never seen it above 175. Regardless of driving conditions or outside temperatures.
Snowman is offline   Reply With Quote
Old 05-05-2012, 05:59 AM   #14
175 degrees 2008 Boxster S, city, highway driveway
ruhiger Fahrer is offline   Reply With Quote
Old 05-05-2012, 07:48 AM   #15
Beelzy's Avatar
This slightly higher temp could be the warning signs that the vanes on the water pump are disintegrating.
Beelzy is offline   Reply With Quote
Old 05-05-2012, 08:21 AM   #16
Ex Esso kid
Or just a thermostat
Old 05-05-2012, 10:26 AM   #17
Or just dirty radiators.
Current car
Previous cars
1973 Opel Manta
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1993 Saab 9000
Old 05-05-2012, 11:35 AM   #18
Ex Esso kid
My car runs at 175 right on the button once warmed
