Old 04-24-2012, 12:26 PM   #1
Question Lost My Center Cap Crest - What Replacement Part Number???
I lost the colored crest from one of my center caps a few months ago, and I’m now in search of a replacement. It appears that purchasing an entire cap is simpler than trying to find the crest itself, but I can’t seem to find the same part number. I’ve attached a picture of what my cap looks like now.
The part number on the back of my cap is 993.361.303.10. I’ve found the same looking caps under 993.361.303.07 & 993.361.303.09 on eBay from the same seller for $42 shipped. Is this an EXACT match for what I’m trying to replace? If so, why would Porsche use different part numbers for identical parts?
Thanks in advance... Dave
dja1980 is offline   Reply With Quote
Old 04-24-2012, 12:48 PM   #2
landrovered's Avatar
The eBay centers are not the same, just went through this. The eBay centers do not fit tight, I had to put some silicon on them to keep the from falling out. The crests are bigger as well.
2001 Boxster S 3.6L, Zeintop
Old 04-24-2012, 12:57 PM   #3
Johnny Danger's Avatar
If you really want to match it, try this site .
Boothe Designs, Porsche parts and accessories, No-Turn Technology
Old 04-24-2012, 01:02 PM   #4
Hmmm... here are the eBay Auctions...
OEM Porsche Center Cap - Silver w/ Gold Crest - 993.361.303.07 - 78mm:
eBay - New & used electronics, cars, apparel, collectibles, sporting goods & more at low prices
OEM Porsche Center Cap - Silver w/ Gold Crest - 993.361.303.09 - 78mm:
Old 04-24-2012, 02:14 PM   #5
The ones I got were like these and they do not fit like the OEM ones.
Porsche Silver Boxster Cayman Carrera Panamera Wheel Center Caps 4PCS/SET | eBay
Old 04-24-2012, 02:25 PM   #6
Ah... ok... thanks.
The ones I linked to are definitely OEM (used), but I still wonder why the different part numbers when they look the same. The only thing I can find online is that they reference different models, but I still don't see why Porsche would do this if they are in fact the exact same...
986 Wheel Cap part no questions - 986 Series Part Number Requests - RennTech.org Forums
Old 04-24-2012, 02:52 PM   #7
These are obviously not genuine OEM...
Old 04-24-2012, 03:56 PM   #8
I did not think they were, I was looking for a cheap replacement which they are. I just thought they would fit better than they did. Once I put a little silicon on the back they are not bad. When I was looking there were no OEM used caps available.
Old 04-24-2012, 05:28 PM   #9
Yeah, they definitely seem to be hard to come by. So, do you guys think it's safe to pull the trigger on one of the eBay auctions I linked to? Since I'm only buying a single cap, I want to be sure they'll match my other 3.
Old 04-24-2012, 05:58 PM   #10
Hurry up already or you will have to buy the kind like I got.
Old 04-24-2012, 06:20 PM   #11
If you're worried about fake just buy from Suncoast or Sunset Porsche...
Center Cap - Full Color (Original Style):Porsche Parts & Porsche Accessories - Wholesale Porsche Parts & Tequipment - Cayman Panamera Cayenn
Old 04-24-2012, 08:44 PM   #12
I found some OEM 993 colored crest caps on ebay cheap......cant tell the difference between the OEM 986 ones
fivepointnine is offline   Reply With Quote
Old 04-25-2012, 06:45 AM   #13
I'm not really concerned about fakes, I'm just confused about the different Porsche part numbers. In my mind, this indicates that there must be some minor difference. Otherwise, Porsche would've used the same part number.
I'm confident that the ".07" & ".09" eBay caps I linked to are OEM, but I'm concerned that there might be a minor difference from the other 3 ".10" caps that are currently on my car.
Thanks for the link though, I didn't know you could buy center caps individually from the "big guys".
Old 05-01-2012, 06:52 AM   #14
I just bought this one. It's OEM, but he didn't list the part#. I'm hoping it will match...
Old 05-06-2012, 10:14 AM   #15
The last digits in the OEM part numbers indicate either a part update or some type of general revision or part variation. On a part as basic as a center cap It could indicate a new OEM supplier, special color/finish, or hopefully better glue used to hold the crest on.
You may want to check your remaining center caps to make sure the crests aren't loose.
I reattached mine with JB Weld after scoring the backs with a utility knife.
1997 Boxster
http://i40.tinypic.com/ax1qhz.jpg
Aron in Toronto is offline   Reply With Quote
Old 05-09-2012, 01:22 PM   #16
Thank you... that's exactly the type of information I was looking for!
My replacement cap came in as ".09" I haven't put it side-by-side with one of my other ".10" caps yet, but I'm pretty sure it matches.
If I find any differences, I'll be sure to update.
Old 12-11-2013, 02:33 PM   #17
heliguy's Avatar
Originally Posted by Aron in Toronto View Post
The last digits in the OEM part numbers indicate either a part update or some type of general revision or part variation. On a part as basic as a center cap It could indicate a new OEM supplier, special color/finish, or hopefully better glue used to hold the crest on..
Better Glue, that's funny.
Old 12-12-2013, 06:24 AM   #18
tanque55's Avatar
Last caps I bought were loose when I got them, I didn't know there was more than one size. Ended up putting some silicone to hold them in place.
tanque55 is offline   Reply With Quote
Old 12-12-2013, 09:31 AM   #19
Bmod986's Avatar
4 Porsche Cayenne Center Cap Sil 911 993 996 997 Boxster New Four Piece Set | eBay
I got mine from ebay and they were great payed $25 for them and they are tight as can be. Unfortunately the seller I got them from does not have them any more but they all get them from china so the link above should give you the same results and they are located in the US. I pointed the tips of the shields to the stem valves and they still are pointing in that direction.
Here is a link to my post.
http://986forum.com/forums/general-discussions/46230-new-center-caps.html
Bmod986 is offline   Reply With Quote
Old 12-13-2013, 05:18 AM   #20
mikesz's Avatar
the dealer wants $200 a set, ebay $25 and they look great.
99 Porsche Boxster
