Old 04-15-2012, 08:14 PM   #1
Loose door bracket
Yesterday I heard a weird clicking noise when I opened or closed my door. I moved it back and forth a little bit to see if I could spot it. Turns out that the middle black bracket from the door hinge to the body is a little loose. The noise is the mount sliding around. I don't know if it's worked its way through the paint, but I will seal it if that's the case.
My question: what size and type of screwdriver does this screw require? It kind of looks like a torx, but I'm not sure. Whatever it is, the thing is massive. It swallowed my torx 30 "like throwing a hot dog down a hallway."
\m/
promark420 is offline   Reply With Quote
Old 04-16-2012, 10:00 AM   #2
It's an 8mm triple square as seen here
Good luck!
Tieniber is offline   Reply With Quote
