topdown light
When i put my top down tbe indicator light came on, thats ok. When the top was put back up the light stayed on.does anyone know where the switch is that activates the light? Maybe its just stuck
Light comes on when top is NOT either fully up or down. Hold button longer and it should go off.
I`ll try that but i think its more than that. Light stays on even after the top is latched closed
It will, the hardest part about the top is holding the button. I still occasionally let go to soon. I have done the mod that lets you put top up and down while in motion. You have to push and hold until light goes off then latch. It takes a few extra seconds that seems like nothing is happening.
1. Don't overfill oil. 2. When putting top down, make sure kleenex box(es) are removed from rear window area- it can dimple plastic rear window. 3. To start engine, clutch must be depressed sufficiently to hear the click and mat must not be behind clutch pedal. I am sure there are more. Enjoy Boxster ownership. I have owned my Boxster for almost a year and always find an excuse to go for a drive rain, snow or shine. Welcome to the forum. If in doubt ask. Enjoy!:) |
AKL;) |
| All times are GMT -8. The time now is 03:03 AM. |
