Old 08-15-2005, 05:30 AM   #1
Arrow 6mm Spacers In Boxster
I am going to install 6mm spacers in my Boxster MY99 (manual transmission) with SportClassic II wheels
Front: 7,5 J x 18 ET 50
Rear: 9 J x 18 ET 52
Two questions:
1. Recommended by Porsche is 5mm...... Can I try 6mm? no problem?
2. Will I need longer bolts or just standard bolts?
Regards.
valcax is offline   Reply With Quote
Old 08-15-2005, 07:41 AM   #2
no use of putting 6mm spacer ,i have try putting 7mm H&R with the 18"-8.5 for the front unnorticeable at all with that kind of money spend .
911sc is offline   Reply With Quote
Old 08-15-2005, 09:19 AM   #3
What do you mean? is there no improvement for handling or look with 7mm spacers?
Old 08-15-2005, 09:42 AM   #4
I bet you could go with 6mm spacers and not hurt your bearings. That's not much difference. Now going to 15-20mm spacers is a different story.
Rubbing on the other hand is a thing of it's own. You'll have to try them to see if you have any rubbing issues. It all depends on the width and height of your tires.
Old 08-15-2005, 09:52 AM   #5
For the wheel bolts, you should be able to turn the bolt 6 turns before it is tight.
KRZ
KRZTACO is offline   Reply With Quote
Old 08-15-2005, 02:08 PM   #6
KRZ
then just standard bolts would be necessary?
RandallNeighbour, tires are:
225/40 ZR18
265/35 ZR18
Old 08-15-2005, 02:37 PM   #7
I don't have experience with tires of your size on your model so I can't tell you if you're going to get rubbing or not. Can anyone else tell him if he's gonna have problems?
Old 08-19-2005, 12:11 AM   #8
Anymore Help ??
