Old 01-24-2012, 04:11 AM   #1
2002 Boxster
Install Cup Holders (suggestions)
Hi, my Boxster has a set of cup holders that need to be replaced. I ordered a new set and they have arrived. In the box are instructions on how to install the entire system which involves removing the radio etc etc. all very daunting.
I was hoping there was a easier way. All I really want to do is replace the two actual cup holder with the new ones and leave all the other attachments in place. Is there an easy way to do this ?
TerryT
TerryT is offline   Reply With Quote
Old 01-24-2012, 08:44 AM   #2
Boxster S Bassist
I have a 2001 S that didn't come with cup holders so simply bought the plastic insert that fits into the locking compartment between the seats.
John Bergen is offline   Reply With Quote
Old 01-24-2012, 09:25 AM   #3
2002 Boxster
Thanks John, although that doesn't quite solve my problem.
Old 01-24-2012, 09:52 AM   #4
How to remove the cup holder Boxster S 2003 - RennTech.org Forums
Wret is offline   Reply With Quote
Old 01-25-2012, 10:08 AM   #5
2002 Boxster
What should I use to pry off the U shaped piece (the arrows near points 1 and 2) a flat nosed screw driver ? If I use that won't I damage both the U shaped plastic piece and the Dash ?
Old 01-25-2012, 05:11 PM   #6
WV Boxster
wvboxst3r's Avatar
start at the bottom with a flat head in a towel. Then work your way up with your fingers. Mine was tight but it will pop. Easy back on.
If your not LIVIN now, then when?
wvboxst3r is offline   Reply With Quote
Old 01-26-2012, 10:31 AM   #7
2002 Boxster
SUCCESS!! Thanks everyone.
Old 02-29-2012, 06:20 AM   #8
DenverSteve's Avatar
What make and model might that be?
Denver Steve
Carrera, Cabriolet, 6-Speed, Black/Tan
DenverSteve is offline   Reply With Quote
