Ground Clearance
Does anyone know what the standard ground clearance is for the 986 using 17" tires.
OR The clearance between the rear tire and the edge of the wheel well? My 99 seems to have very little tire to well clearance (less than 2 inches). Maybe I have a different suspension package? |
John99 , Mine is pure stock and I have no room with recomended tires.
John, I have a 2000 'S' and my manual says 4.1 inches of ground clearance. Bentley says "Front axle ride height is measured from road surface to lower bolt head edge connecting tension strut to body" and "Rear...to lower edge off diagonal brace at control arm mount". 5.98 inches front, 5.75 inches rear. Numbers are smaller for ROW and Row Sport. Don't think this helps with your issue though.
John99 - I'll measure my '99 tonight and let you know..
| All times are GMT -8. The time now is 11:45 AM. |
