-   -   1st Freezing morning - Condensation (http://986forum.com/forums/boxster-general-discussions/31146-1st-freezing-morning-condensation.html)
John99Boxster 11-18-2011 04:53 AM
Well the temperatures finally dropped in Eastern NC to a chilly 34 degrees this morning.
Went out to start the car and noticed heavy condensation on the INSIDE of the windshield!! Nothing on the OUTSIDE?
Is this a common Convertible Top issue or Is there some other cause for this?
stephen wilson 11-18-2011 07:09 AM
No, it's not normal. You're getting moisture inside from someplace. I have had it happen once, getting in and out during a heavy rain let in enough moisture to cause condensation, but it dried out quickly once the weather cleared.
blue2000s 11-18-2011 10:01 AM
It IS normal, according to this thread from a year ago.
http://986forum.com/forums/general-discussions/27661-rear-window-condensation.html
WhipE350 11-18-2011 03:55 PM
John - Did that front with rain blow through yesterday...it did here. It had been windy and raining. It is possible moister blew in the car and the temps dropped very fast as they did here. Basically the left over moisture in the car didn't get a chance to escape, the plastic cools very fast and reached the dew point inside the car, dew forms on the window and then with the rappid temp drop freezes on the plastic before it can evaporate.
It's going to be cold again tonight and the cold dry breezes today should have balanced the moisture in your car with the outside, see how much is on it in the morning on Sat. With the rapid temp drops I'm not saying you won't see any because the plastic cools so fast (ie before the temp inside the car can drop) but there should be less.
John99Boxster 11-18-2011 04:34 PM
Whip....good insight...but the condensation was on the inside of the front windshield....I have a glass rear window and it was fine.....the side windows were clear as well.....just the interior of the windshield. Very strange.
Yes, we did have a pretty strong front blow through last night and the temps dropped very quickly.
I hope tomorrow morning reveals a clear windshield. If not, I will have to research other potential problems.
thanks for your insight.
WhipE350 11-18-2011 04:45 PM
Shows how closely I read while working at the same time. Either way most of the science holds up :). Ya either extra moisture in car or things cooled pretty fast as they did here. Was it facing northwest ;)
