11-14-2011, 01:48 PM
#1
Misfire, Cylinder 4
Had a CEL with a code of Misfire on Cylinder 4. Replaced the Spark Plug, Tube and Connector. Still misfiring at higher gears when I "punch it".
What else could it be? The Coil itself? The Wires?
What would you do?
1999 Boxster
Ocean Blue Metallic/Savannah Beige | Tiptronic | Custom Rear Spoiler | 17" Turbo twist | Red Brembo Calipers | GAHH Top w/Glass Window | Tinted Windows | Cruise Control | Leather Interior | Heated Seats | Color Wheel Caps | Traction Control | Debadged
11-14-2011, 03:19 PM
#2
John, My feeling is wire. I had this problem 2 months ago with another engine, WIRE was the problem when pushing the "pedal" down. Good luck. Max in Beaufort
11-14-2011, 03:57 PM
#3
Check the coil pack for cracks.
11-14-2011, 05:00 PM
#4
Max...thanks. Any idea of the part number or official name of the wire is?
1999 Boxster
11-14-2011, 05:09 PM
#5
1999 Boxster
11-15-2011, 12:46 AM
#6
John - the "wires" seldom fault unless eaten out by rodents - they are 12 volt Low Tension.
The normal cause for ignition faults lie with the coilpack itself - usually starting with cracks in the insulation and made worse once moisture gets into the cracks, causing a misfire.
Replace the suspect coilpack and inspect the other 5 - once one has failed, the others seem to follow soon after.
Plus 6 x new coil packs seem to give a decent boost in performance too.....
2001 MV Agusta F4.
11-15-2011, 05:52 AM
#7
John, Not sure about the wire. It was same problem but on a different engine(not Porsche) The coil makes sense ... also. I have a slight miss ( I think) at idle at the stop sign. Yesterday was the first trip out on the road since fuel pump replacement and noticed a little shake. Let us know , John !!! Max
11-15-2011, 08:59 AM
#8
Just swap a coil pack from another cylinder to #4, if 4 doesn't misfire, then its the coil pack. If it still misfires, then look to the wiring.
Current car
2000 Boxster 2.7l red/black
Previous cars
1973 Opel Manta
1969(?) Fiat 850 Convertible
1979 Lancia Beta Coupe
1981 Alfa Romeo GTV 6
1985 Alfa Romeo Graduate
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1989 (?) Alfa Romeo Milano
1993 Saab 9000
11-15-2011, 11:36 AM
#9
Ordered Coil Pack today....will be here tomorrow. I will update then.
1999 Boxster
11-16-2011, 11:22 AM
#10
Got the coil pack.....replaced the old one in cyl. 4. Drove it "Like the Doctor Ordered" and no misfire!!
Feels good to accomplish little things!!!:dance:
Picture of old coil...missing 3 pcs./cracked:
http://986forum.com/forums/attachments/boxster-general-discussions/15656d1321471326-misfire-cylinder-4-img_20111116_141217.jpg
1999 Boxster
11-16-2011, 03:21 PM
#11
John, Good news to know ! I was in Wilmington today and did not see a flash go by. By the way the past owner was from Hampstead and bought tires from McGill on Market st???? rear @ $102.87 front@ $111.76 ???? Do you have any info? Thanks, Max
11-16-2011, 05:10 PM
#12
Yep, I guessed right.
11-17-2011, 01:15 PM
#13
Hi Max....lol at the "flash" passing by. I am not familiar with McGills...I usually go to Black's. What kind of tires (make/size) do you have on the car now?
1999 Boxster
11-19-2011, 06:15 AM
#14
Hi John, Lot's of flash in your town !!! Tires--- Kumho ecsta asx 255 40 17 rear and 205 50 17 front These were bought by the past owner. They look a little worn but I do not know what they look like new. I need an inspection the first of Dec and do not need to fail. Are these prices in line? 255 $111.76 205 $102.87 At McGill's on Market st. Thanks again John as we are 2 hours away. Max in Beaufort
11-19-2011, 12:32 PM
#15
Max, my tires are as follows:
front. TOYO Proxes T1R ...$137 ea. 205's
rear. Nexxen N3000....$108 ea. 255's
So, yes your prices are in line. Looks like a difference of $60 in your favor on tires. I may need to check out McGills. I just dont know anything about Kumho's. Are they Directional tread tires? My Toyos and Nexxens are.
1999 Boxster
11-20-2011, 07:18 AM
#16
Thanks John, I will check out Black's as well. Thanks for the info. Let me know when the Eastern NC club gets started as I will join ! Take Care Max
