Old 11-13-2011, 07:05 AM   #1
John99Boxster's Avatar
P0304 and P1316 Codes
I got the P0304 - Misfire on cyl. no. 4.
I replaced the spark plug, the spark plug tube and the spark plug connector....Hope that does it. Otherwise it has to be the coil.
P1316????? Can anyone interpret this one for me.
Also....if I fixed the misfire and the P1316 is not a big issue....can I disconnnect the battery to clear the light....now that I have the codes?
1999 Boxster
Ocean Blue Metallic/Savannah Beige | Tiptronic | Custom Rear Spoiler | 17" Turbo twist | Red Brembo Calipers | GAHH Top w/Glass Window | Tinted Windows | Cruise Control | Leather Interior | Heated Seats | Color Wheel Caps | Traction Control | Debadged
John99Boxster is offline   Reply With Quote
Old 11-13-2011, 08:02 AM   #2
You could always call a local shop. They probably have a scan tool that will pull out all codes, even ones that won't set a check engine light, and will be able to reset them all for you.
Mrmaddbrad is offline   Reply With Quote
Old 11-13-2011, 08:37 AM   #3
I figured out the P1316....Basically same as the P0304 -P1316 Misfire, Cylinder 4, Emission Relevant.
And the official P0304.....P0304 Misfire, Cylinder 4, Damaging to Catalytic Converter
Fixed.....Unhooked Battery.....CEL gone
1999 Boxster
