Old 10-30-2011, 04:09 PM   #1
Question Water Pump
Hi guy out there,Long time I've been out of the forum because my porsche been doing fine, anyway i always check on you guy for new post.
Ok now here I go i park my 2001 bosxter base in the garage and the next morning I saw some coolant fluid in the floor,I lift the car and the coolant is coming from the bottom part of the water pump and some wear noise like the bearing is ware out.
I check in other post about this but I will like some advise or tips in my case any help will be appreciate it.
andre69 is offline   Reply With Quote
Old 10-30-2011, 04:20 PM   #2
I just performed this repair. There are posts out there that gives you step by step instructions on how to do it.
I believe I paid $150 for the replacement part.
crumbum is offline   Reply With Quote
Old 10-30-2011, 06:20 PM   #3
Thanks for your post but if you please can help to find it ,because I look through the old post and threads and i could't find nothing.Thanks again.
Old 10-30-2011, 06:44 PM   #4
Here's a couple:
Pelican Technical Article: Boxster Water Pump & Boxster Thermostat Replacement - 986 / 987
Replace Water Pump
Old 10-31-2011, 11:55 AM   #5
Yup, these were the two guides I used along with a download of the official workshop guide just to check the torque settings. It's not a very difficult job apart from perhaps one bolt that's a bit tricky to get. But I'm a total novice and had no real problems.
