Old 10-26-2011, 10:12 AM   #1
My heater working?
Used the heat for the first couple of times but doesnt blow very hot, more warm. Is this normal, or am I not turning it on properly? 99 boxster' I turned heat up to 'hi' and b lower to high as well. A/c symbol is off. Thoughts? Thx
nprboxster is offline   Reply With Quote
Old 10-27-2011, 09:55 AM   #2
Registered Boxster abuser
healthservices's Avatar
I've read that the blend door on some models fall apart causing lack of heat. Not sure if this applies to you. Do you have any loose foam bits in the a ducts?
Old 10-27-2011, 10:39 AM   #3
Heater? Who needs a heater?
Ron, in SAN DIEGO
ChairmanRon is offline   Reply With Quote
Old 10-27-2011, 02:34 PM   #4
yes constant foam pcs coming out of vents. so whats it mean for my heater?less heat cause of foam missing/chunking? what do i do?
Old 10-28-2011, 09:11 AM   #5
The Blend door is built a little strange, it may for sound deadening? but from what I saw the door is a holey plate with a foam piece covering it. When the foam deteriorates the door can not regulate the hot/cold air anymore as it is bypassing threw the openings.
Removal of the heater box is required to repair this.
