Old 09-16-2011, 04:24 AM   #1
Trans fluid change - whats normal
Hey all,
In the middle of changing my trans fluid for the first time. The previous change was done 12-30k miles ago, not sure exactly when. I felt some notchiness going into 2nd gear that I thought might not need to be there, so I picked up some mobil delvac 75w90 and am putting it in this morning.
On every other trans fluid I've changed (manual trans), the drain plug has a magnet built into it and it's always covered with a fine grit of particles from normal transmission wear. This can be seen as a dark even-grained sludge sitting on top of the drain plug when you pull it out.
When I pulled the boxster's drain plug, it was spotless. Nothing but an even coating of lightly colored gear lube.
Is this normal for the boxster or do most people experience some particulate build up there?
Joe
P.s. Either way, I'm not displeased
99 Boxster 5spd - 64k miles
06 Civic SI - 114k miles, D.D., unbelievably reliable and fun to beat on everyday.
08 Legacy GT 5spd - 74k miles.
JoeFromPA is offline   Reply With Quote
Old 09-16-2011, 04:44 AM   #2
Sounds normal. You don't really have that many miles on the fluid. The only way to really know for sure (or more) is to do a used oil analysis, with a lab like Blackstone.
Old 09-16-2011, 07:17 AM   #3
Hehehe, too late now!
Drives great. Whatever fluid had been put in before must've been the right stuff - there's barely a notable difference betwen the two. Just put 32 miles on it including a few runs to redline and so far everything feels great.
Old 09-16-2011, 07:52 AM   #4
The Radium King's Avatar
the magnet isn't located on the drain plug, but just in front of it. next time you have your plug out, give it the finger and you'll find your metal bits.
Old 09-16-2011, 05:17 PM   #5
Steve Tinker's Avatar
RK - what do you mean re the magnet - is it located in the gearbox itself and not (as normal) on the drain plug itself? If so, how do you remove it for cleaning - there is no mention in the Bentleys Manual.....
2001 MV Agusta F4.
Old 09-18-2011, 02:53 PM   #6
here you go ...
http://www.youtube.com/watch?v=VAl9g_Oar7I&feature=related
Old 09-18-2011, 06:49 PM   #7
Huh - that doesn't look accessible through the drain hole (drain hole too small). That's just my guess.
That's also a scary video about the durability of those 6-speed trans....
Old 09-19-2011, 02:15 AM   #8
Great. So the transmissions have sealed bearings, like the IMS, that are also subject to failure.
Current car
2000 Boxster 2.7l red/black
Previous cars
1973 Opel Manta
1969(?) Fiat 850 Convertible
1979 Lancia Beta Coupe
1981 Alfa Romeo GTV 6
1985 Alfa Romeo Graduate
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1989 (?) Alfa Romeo Milano
1993 Saab 9000
Old 11-24-2011, 08:44 PM   #9
Matt
MileHighBoxster's Avatar
All bearings are subject to failure. It just doesn't happen very often.
MileHighBoxster is offline   Reply With Quote
