Old 09-06-2011, 09:47 PM   #1
Rear Spacer recommendation *Pic included*
Sorry for the bad picture/angle of the picture. It's the only picture I currently have on my computer that my nephew took.
I'm not sure if you can tell from the pictures or not, but the rear tires are tucked in and I would like to add some spacers to the rear to fill out the rear fender. How many mm spacer(if you can even tell) should I add? Also, is there a difference in brand? Will I have to get an alignment after adding spacers. How will spacers effect the handling?
ohhh my is offline   Reply With Quote
Old 09-07-2011, 07:19 AM   #2
Johnny Danger's Avatar
Assuming that those are Victor Zehn wheels (9.5 +49 et ), depending on how aggressive you want to go, a 10 -15 mm spacer will bring the rear wheels out nicely . Also, no alignment is necessary, and changes in handling are subjective. As far as brands are concerned, if you search the forum you'll find some threads regarding good sources to purchase them from .
Old 09-07-2011, 12:14 PM   #3
Thanks!!15mm it is!
Old 09-07-2011, 01:16 PM   #4
Damn sexy Boxster ohhh my! Post more photos when you get the spacers mounted up!
Appleguy is offline   Reply With Quote
Old 09-07-2011, 01:25 PM   #5
Thanks. Here's 2 more for now...
Old 09-07-2011, 07:57 PM   #6
Wow, your vehicle is really slammed . How is it lowered ?
Old 09-07-2011, 08:06 PM   #7
Dead bodies in frunk and trunk with Eibach springs and blistein shocks.
