Old 08-27-2011, 02:26 PM   #1
2003S's Avatar
Driver's seat issue
So I thought I just needed a new height adjustment lever, but after tinkering a bit, I see the lever is just fine. I followed the cable that the lever is attached to, and it goes to a cylinder that presumably adjusts the height of the seat. I put the channel lock on the end, pushed and pulled a bit, and can't get it to engage.
Anyone else have this fail on them before? Looks like the prior owner pulled on the lever a bit hard, and broke a spring that resets the lever, but otherwise, I think everything else under the seat is intact.
Any other way you can think of to engage that cylinder? I'd really like to drop that seat just a bit...
Old 08-27-2011, 03:51 PM   #2
DenverSteve's Avatar
I'm not sure what you're asking. The lever doesn't do anything but allow you to move the seat with your legs. Pull up (I believe I'm not in the car and I don't adjust the seat as it is adjusted the way I like it) and slide back/up or forward/down using your weight to move the seat. Then release the lever. If you're already doing that, disregard. It is a little different than anything else I've adjusted. It is also in the owner's manual.
Denver Steve
DenverSteve is offline   Reply With Quote
Old 08-27-2011, 07:47 PM   #3
2003S's Avatar
Thank you!
I didn't do a good job of explaining, but you got me on the right track -- I had been thinking that lever automatically moved the seat up & down - looking at the mechanism (upside down, with a flashlight), I got what you are saying -- can't move it without sitting in the seat.
The cable hooked to the lever is completely mangled, but I did get my vise grip on where it is supposed to engage, levered it, and presto, I can move the seat up and down.
The cable mechanism will have to wait for another day to get fixed -- got the seat in a good position!
Thanks much.
2003S (aka Chicago Steve!)
