Old 08-26-2011, 10:05 PM   #1
DenverSteve's Avatar
Door Panel Renewal
My door panels were beginning to get a little worn on the plastic parts. The gray finish had become a little scratched and I wanted the clean look back. I thought about replacing the panels but that was going to cost a bit as you know. I considered painting them but didn't want the paint smell permeating the car even for a short time.
After looking on line I decided on the 3M Carbon Fiber Vinyl Car Wrap in Anthracite. It has a very similar texture as some of the interior including the non-leather areas of the dash and door panels. It cost $25 for 5 sq. ft. of material and, as you know, that's far less than new door panels.
Denver Steve
Carrera, Cabriolet, 6-Speed, Black/Tan
DenverSteve is offline   Reply With Quote
Old 08-27-2011, 06:21 AM   #2
schnellman's Avatar
Looks Great
You did a heck of job.
Old 08-27-2011, 07:29 AM   #3
what is that diamond pattern that the majority of your door is made out of...
Old 08-27-2011, 07:31 AM   #4
Just my factory door panels - dash too. I don't know how many different interior trims they had.
Denver Steve
Old 08-27-2011, 01:46 PM   #5
crazy i have never seen a porsche with that pattern before.
Old 08-27-2011, 02:44 PM   #6
DS-
That looks great!
silverboxter is offline   Reply With Quote
Old 08-27-2011, 05:02 PM   #7
Autobahn Glanz
WhipE350's Avatar
Steve - that is nice! Does it just stick on...what is the process?
Old 08-27-2011, 05:08 PM   #8
You first cut the material to a size/shape that you can work with for the item you are covering. Then you peel the backing paper off and place the vinyl on an area central to the part you are covering. Then you heat the material up using a hand-held hair dryer which makes the vinyl much more pliable and stretchy. You continue to heat and stretch the material pressing it into place and pushing it into place. It adheres by the adhesive on the back and the hardening/shrinking process as it cools. It's very easy to work with and there are several instructional videos on UTube demonstrating its use.
Of course, it looks even easier on large symmetric pieces when shown on line by experienced installers. If I can do it, anyone can.
Denver Steve
Old 09-05-2011, 09:29 PM   #9
CVBoxster
This does look good, I was planning on painting these plastic parts but this might be easier. I will try using matte black. Thanks!
rafibanez is offline   Reply With Quote
Old 09-06-2011, 08:49 AM   #10
looks good
Yeah.... I kind of like it. Mine is space-gray. Do they make it in that color?
sean
SeanZ4 is offline   Reply With Quote
Old 09-06-2011, 05:25 PM   #11
Try here. This is where I got mine. 3M is available through numerous sites.
http://stores.ebay.com/IMPORT-CAR-PARTS-PLUS?_trksid=p4340.l2563
Denver Steve
