-   -   02 Boxster clutch problem? (http://986forum.com/forums/boxster-general-discussions/29844-02-boxster-clutch-problem.html)
mikesaletnik 07-29-2011 08:38 AM
Hello I have an 02 Boxster with 86,000 miles. I recently drove the car to a friends house and everything was fine, when I went to leave the clutch started slipping and finally went altogether. There were no signs of a problem previous to this. No slipping, no grinding, and no smell of a burning clutch. The pedal has pressure and you can hear it going into gear when you shift it. However it just acts like it's in neutral. Any ideas? THANKS!!!
Gilles 07-29-2011 11:41 AM
Mike,
You may have a CV joint that became loose, check underneath and if this is the cause they are pretty simple to reattach.
DenverSteve 07-29-2011 08:39 PM
Sometimes that happens. Get thee to a mechanic and get the clutch checked out.
smagerstein 07-30-2011 03:55 AM
Hi,
This is exactly what happened to me a couple months ago.
Just went in a flash. New clutch and new dual mass flywheel. 3000€ :(
prairiefire 07-30-2011 09:48 AM
2002 S of mine 120,000 km's started as a soft clutch peddle then slipped at higher load. The pressure plate once removed I found half the fingers about a quarter inch out of wack with the other. So I ordered clutch disc and pressure plate and most importantly the disc alignment tool.
I did the replacement myself and it was the easiest clutch I ever changed! CJ 5 jeep, TJ jeep, F-150, and Honda Civic I have done in the past. Other then one bell housing bolt with irregular head (special socket, which air grinder looked after and regular bolt replaced it). Really it was simple and straight forward if your comfortable spinning wrenches.
jack stands and floor jack used, basic hand tools. The Boxster tips book from Pelican walks ya through it pretty good.
Pressure plate collapsed is what it sounds like
