Old 07-12-2011, 07:11 AM   #1
Unhappy Intermittent alternator whine
I have this annoying whine in my stereo that comes and goes. About 3 years ago I replaced the head unit with a reconditioned Kenwood GPS receiver. It worked great for 2 years and then started having this weird issue when the volume would decrease and there would be a whine coming through the speakers that varied with engine speed. As it all worked fine for 2 years and I always suspected the Kenwood because the radio reception was never great. About 3 months ago I got fed up with it because the GPS started to go crazy (loose maps) so I had the unit replaced.
It worked fine for about a month or two but then the whine noise came back. Again, it comes and goes, and its always comes along with the sound getting "mutted". That is a real issue because I normally up the volume when this happens and then a few minutes later I am blasted by the loud volume when it "starts working again".
I now think it's the amp because when I "jiggle" the connectors on the amp the problem seems to go away for a while. I don't think its the ground because it would not be so intermittent. Any ideas? Should I replace the amp?
Rob
1999 Boxster Red/Blk
2007 BMW 328 Coupe Arctic/Tan
1993 Lotus Esprit SE Red/Tan
rteichman is offline   Reply With Quote
Old 07-12-2011, 06:38 PM   #2
darkstormvx's Avatar
I had the same problem when I first had my audio system installed. I think they put something in between the connection of my amp and the battery. A small filter on the line or something. Whatever they did, it only took 1 min to put on and the noise was gone.
Try an audio install shop?
Black/Black 987 2005 S
darkstormvx is offline   Reply With Quote
