Old 06-29-2011, 10:01 AM   #1
Rear Window Fix vs. Replacement
I have a small crack in the plastic rear window by the stitching. I was thinking of replacing the window itself and having a new one stitched in...
In doing some research, it looks like I can get an new acoustic A5 top with a glass window and defroster for around $550 (plus install)...
I guess the question is, why WOULDN'T I just replace the whole top and get a glass window for a few hundred dollars more??
Thoughts?
Thanks!
Rick
2002 Boxster S
Rfromet is offline   Reply With Quote
Old 06-29-2011, 10:13 AM   #2
The only downside I've heard of the glass tops for the pre 03s is the fact they can limit engine access.
tawheed is offline   Reply With Quote
Old 06-29-2011, 10:31 AM   #3
jdiba's Avatar
$$$. If you have a replacement done you can get insurance to pay for it. I went
that route.
jdiba is offline   Reply With Quote
Old 06-29-2011, 10:34 AM   #4
Track rat
Topless's Avatar
In SoCal you can have a replacement window installed in your OEM top for $385 and an aftermarket top with glass window installed for about $1200. It is easier to access you air filter and MAF with the original top and the original always seems to fit perfectly. The glass window looks better. Pick your poison.
Old 02-27-2012, 01:07 PM   #5
2006 987
986_inquiry's Avatar
I'm facing the same problem, plastic rear window is detaching from the fabric top.
$385 for new rear plastic window with installation sounds reasonable, anyone know of someone in St. Louis that offers this service at that price?
986_inquiry is offline   Reply With Quote
Old 02-27-2012, 02:22 PM   #6
2001 RUF 3800S
violametallic-S-'s Avatar
im shopping for a new top with the glass in it, looks a lot better then plastic. where did you see 550?? for that very good deal... let me know please
Thoughts?
Thanks!
Rick
IG: RUF3800S
violametallic-S- is offline   Reply With Quote
