Old 06-24-2011, 04:37 PM   #1
Jager's Avatar
Radiator Cleaning
Do you want to see what the radiators collect after 10 years and 212,000 miles? See attached pictures.
I decided to clean my radiators today (saw someone else doing it on another post). Why didn’t you guys tell me I needed to do this? Think I removed about 20 lbs. of crap from the front of my car. I had to laugh at the Styrofoam peanuts and cigarette butts. After seeing all of this, it’s probably a good idea to clean the radiators every 50k miles or so. I used a spray cleaner and hose to blast the dirt and dust out-of-there.
Jager
Old 06-24-2011, 04:58 PM   #2
I just finished doing mine. Wow, the amount of garbage was unbeilable. I live in florida and a had a beach full of sand on the drivers side. Radiator cleaning is definitely a maintenance item. I was starting to get a little rust on the lower outside corners which hopefully won't spread any more.
I was thinking of hitting the rust with phosphoric acid. What do you think?
Current car
2000 Boxster 2.7l red/black
Previous cars
1973 Opel Manta
1969(?) Fiat 850 Convertible
1979 Lancia Beta Coupe
1981 Alfa Romeo GTV 6
1985 Alfa Romeo Graduate
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1989 (?) Alfa Romeo Milano
1993 Saab 9000
Old 06-24-2011, 05:27 PM   #3
Jager's Avatar
You have exterior corrosion on your radiators? I’m not sure what phosphoric acid will do to your radiators, I have used it only on steel.
Old 06-24-2011, 06:22 PM   #4
I guess you're right, the rad is all aluminum, so phosphoric acid won't do anythhing.
Current car
Previous cars
1973 Opel Manta
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1993 Saab 9000
Old 06-24-2011, 10:06 PM   #5
I've not done this, and probably need to.
May be a dumb question, but did you hose it from the front, or is it possible somehow to flush from the back?
Old 06-24-2011, 10:13 PM   #6
Jager's Avatar
The AC radiators were hosed/washed from both sides (they also seem to be the dirtiest) but the engine coolant radiators were hosed just from the front. This is a better picture for showing both the AC and engine radiators.
Old 06-24-2011, 11:30 PM   #7
another dumb question, but is removing the front bumper one of those projects where it doesn't go back together quite right (or line up just right after reinstall?)
I always have trouble with stuff like bumpers, trim pieces etc where they don't look quite right after re-installation.
any trouble? one-man job?
stateofidleness is offline   Reply With Quote
Old 06-25-2011, 01:57 AM   #8
Good job mate. Got mine cleaned when I got the car 3 months ago... it was time to fit the Gt2 front bumper and I also didn't know that rad place was designed as 'garbage collector'. We found a small bird skeleton in the lower corner of one of the rad. Road Kill Du Jour!
madmods is offline   Reply With Quote
Old 06-25-2011, 08:04 AM   #9
Jager's Avatar
I had no problem putting the bumper back on myself and you can't tell it was removed. In fact I went to a local Porsche shop to pick-up a part and the owner and employee came out to look at my car and commented that you can't tell I took the bumper off. Have you seen the video clip on YouTube on how to remove the bumper? There are two clip connector screws (bottom of the side marker lights) that are a little tricky to get to but once you know where they are it's not too bad to get them off.
Old 06-25-2011, 12:37 PM   #10
Autobahn Glanz
WhipE350's Avatar
Yes they are very nice little debris collectors. Mine looked like they went through seasonal decomposing, almost like it settled after each fall and then turned to nice potting soil.
Old 06-25-2011, 02:21 PM   #11
What a differnce the claening made. The car runs much cooler now. When dirty, temp in stop and go traffic was always past the 0 and just shy of the 215 mark. Now its between the 8 and 0 and the climate control on board shows that the coolant temp is consistently just below 100C.
Current car
Previous cars
1973 Opel Manta
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1993 Saab 9000
Old 02-27-2013, 08:22 PM   #12
Vista glass
Vista glass's Avatar
High speed compost heap
I read , I learned, I did. Wow was there a lot of material in my radiators.It looks like I have gone where no man has before.
My temps were elevated around 215 on the gauge. AC not cooling very well. Neither of these scenarios are desirable here in sunny Florida. Thank you 986 forum members for the guides. I even found a U tube video. Sweet.
This forum laid out the process and the procedures. I took a little longer than some but I was checking on everything made visible. I had done the Frunk release hack so when I was removing the cover the release cable was attached to the towing eye tether. No big deal just a surprise that wasn't in the guides.
I fixed a few other discoveries while thus engaged. I certainly need to get a box of those plastic paneling rivets ! Funny the pre-purchase inspection did not mention the loose and missing parts. After seeing the variety and size of the stuff was in the radiators I decided to screen the intake ports. I used aluminum screen and epoxy to attach it.
I will advise if that screen attachment method is effective enough to endure time temperature and rapid forward motion.
Vista glass is offline   Reply With Quote
