Old 06-22-2011, 06:38 AM   #1
Question how to clean headlight lens
Does anyone know how to clean headlight lens? I bought a product but no results
Sandro is offline   Reply With Quote
Old 06-22-2011, 08:36 AM   #2
kpm
I like Meguires Plastix polish for the headlight covers on my Boxster. Also does a good job on the plastic rear window too.
kpm is offline   Reply With Quote
Old 06-22-2011, 09:06 AM   #3
1500 grit wet sand until smooth and uniform, then take a right angle buffer (or drill) and attach a polishing wheel (foam) with clear lens polish until shiny. Then hit with an automotive clear coat or reduce 2k black paint and mist for tinted look.
theprofessor is offline   Reply With Quote
Old 06-22-2011, 10:19 AM   #4
Or you can 500 / 1000/ 1500/ 2000 and then polish either with a buffer (either rotary or orbital) or by hand with a good polish/swirl remover.
Either way is pretty effective.
zilla is offline   Reply With Quote
Old 06-22-2011, 10:35 AM   #5
Wink
Thanks guys will try this week-end
Old 06-22-2011, 11:08 AM   #6
Smile Headlight
I have great results with Plexus spray.
JDBOXSTER is offline   Reply With Quote
Old 06-22-2011, 12:03 PM   #7
Question
Plexus spray?? where is this sold?? Is it hairspray by any chance??
Old 06-22-2011, 01:19 PM   #8
laphan's Avatar
I used Meguiares on my older DD and it worked. I bought the headlight restoration kit and it came with a sponge that attached to my drill.
My headlamp was completely yellow, it almost made no difference driving with headlamp on or off before. It restored my headlamp to 90% new.
The main issue is, they start to be yellowing again this year (after 1 year) and I have to re-do the whole process again.
laphan is offline   Reply With Quote
Old 06-22-2011, 02:30 PM   #9
J Tinsby's Avatar
Same thing here with 3M kit
Originally Posted by laphan
I
I tried the 3M kit with similar results on my '99 New Beetle. It did work but shortly after the yellowing started again.
I understand that one of these headlight restore kits has some sort of an alleged "preservative" that you put on after you have cleared up the lens. Sorry I don't know what manufacturer makes this.
"Never force it.... get a BIGGER hammer!"
J Tinsby is offline   Reply With Quote
Old 06-22-2011, 02:45 PM   #10
ppbon's Avatar
The problem is that...
... unless you apply a protective UV coat it will yellow again.
The UV coat s available are only sold to professionals and most of them have to be air sprayed on.
I've done quite a few Boxster headlights with this UV coat and we guarantee them from yellowing up to 3 years.
I don't know why these UV coats aren't sold to the general public.
Happy Boxstering,
Pedro
ppbon is offline   Reply With Quote
Old 06-25-2011, 06:29 AM   #11
GTA_G20's Avatar
I dont know about you guys but I tried doing this last year and it seemed as if there was some sort of film on the lense and I couldnt quite remove it...
2006 Audi A4 Avant 2.0t Quattro
1997 Boxster Glacier White w/facelift(gone but not forgotten)
2004 Boxster S 550 Spyder Anniversary Edition
GTA_G20 is offline   Reply With Quote
