Old 06-16-2011, 11:21 PM   #1
How to tell if you have litronics?
Is there a visual different within Litronic and non-Litronic headlights on the 986?
rdougan is offline   Reply With Quote
Old 06-16-2011, 11:41 PM   #2
litronics are xenon projectors. regular headlights are reflectors.
ASpec818 is offline   Reply With Quote
Old 06-16-2011, 11:42 PM   #3
I was looking for a little more detail (I don't know the difference between those two things...)
Old 06-17-2011, 02:19 AM   #4
Litronics have clear turn signal lenses, and halogen has amber lenses. Litronics also have ride height sensors on the lower control arms.
kcpaz is offline   Reply With Quote
Old 06-17-2011, 04:53 AM   #5
Not sure these answers have helped the original poster, as 2003+ halogens also have same reduced amber for turn signals as litronics.
Litronics have a approx 2.5 inch round circle from which the main beam projects a very focused light. You can see this clearly when looking at the headlight, even if it is not on. Non-litronics look like regular headlights.
2001 Boxster S, Seal Grey
1998 M3, Estoril Blue
carguy is offline   Reply With Quote
Old 06-17-2011, 05:29 AM   #6
Opposed to Subie Burble
Overdrive's Avatar
litronics looks like this:
see the round projector in the middle that carguy mentioned?
regular (halogen bulb) headlights look like this:
Now if you're asking if there's a difference in the light they produce, basically you'd be looking at that normal, slightly yellowish light coming from regular halogen lights, and a whiter, more focused beam coming out of litronics.
Hope we've been able to help, if not please be more specific in what you're looking for.
-O/D
IMSR + RMS
Robbins glass window top
Old 06-17-2011, 06:47 AM   #7
IIRC, litronics also have headlamp washer jets and the Halogens don't as seen in the above photos.
1997 Boxster
http://i40.tinypic.com/ax1qhz.jpg
Aron in Toronto is offline   Reply With Quote
Old 06-17-2011, 07:22 AM   #8
^Litronics retrofit kits do not have the headlight washers.
Old 06-17-2011, 03:03 PM   #9
Ok, that has helped a lot.
I think I have the litronics then, as I have the washers. Where is the washer switch located?
I'll take a closer look latest and see if mine has the projectors.
Thank you very much!
Old 06-17-2011, 05:55 PM   #10
Multi-Boxer Driver
Deserion's Avatar
I believe you press forward on the windshield wiper stalk, versus pulling back. I may be wrong though.
-Chris
2004 Porsche 911 C4S Cab
1991 Porsche 911 C2 Targa 3.6
2017 Subaru Outback 3.6R
Old 06-17-2011, 06:10 PM   #11
I just looked and it seems I do have the litronics. Awesome.
