What Size Spacers for 18 inch Porsche Wheels?
I have a set of OEM 18" sport design rad wheels on my 2000 S, 7.5" ET50 front 9" ET52 rear. What size spacers do I need in order to have a flush look?
I understand from searches that 996s with the same sport design rad 18" wheels need 7mm front and 14mm rear to make it flush, but it might be different for 986s? [IMG]http://t1.gstatic.com/images?q=tbn:ANd9GcQP73tv6I9W9TwKGzRqGMTofdBRl4uKC 73xSH-RxaLlJii2_RMb [/IMG] Thanks :cheers: |
well simply measure how much space is left between the outside of the tire and the inside of the fender well
That;s the size spacer you need |
To put things in perspective, most enthusiasts who upgrade to 18 or 19 inch wheels who are targeting a "flush" look, typically run fronts that are either 8 or 8.5 inches wide with offsets ranging between +38 to 45 depending on the width and rears that are 9 to 10 inches wide, with offsets ranging from +30 to 45 depending on the width . These are general guidelines, and things such as tire size, suspension set-up, as well as how "aggressive" one wants to his or her vehicle to look, can vary between fitment .
Sorry I see you said what you have...so you just want to add to the look...ya just take a rough estimate by measuring, I also did this, and give it a shot. |
