Old 05-21-2011, 03:06 PM   #1
2003 Boxster - Crank No Start
So I am having my first problem with my 03 boxster.
Pulled it out of the garage last week, as I was waiting for the garage door to close the car started stuttering and then engine shut off.
Tried to restart, it cranks but engine won't run.
Here is what I have done so far.
1) Check for codes - No Codes present
2) Replaced battery with a new one
3) Replaced DME, Ignition/O2, Blower Engine Comp and Fuel Pump Relays with new ones
4) New Ignition switch
Car still wont start! I left it cranking for >15 seconds and was able to get engine run for a few seconds, but it felt as if only 1 or 2 cylinders were running, then it shut off and won't start. Still no codes present.
Has anyone had a similar issue? If so how did you get it fixed? What else should I check? Thanks!
apac is offline   Reply With Quote
Old 05-21-2011, 04:52 PM   #2
Jager's Avatar
Have you checked fuel delivery system? Fuel preasure? Maybe fuel filter problem?
Jager
Old 05-21-2011, 05:10 PM   #3
Jager
No I have not. I will check the fuel filter. Not sure how to check fuel pressure.
Old 05-21-2011, 05:17 PM   #4
Spinnaker's Avatar
Just for kicks, try putting some gas in the tank. Boxster fuel gauges have been known to go bad. Might save some expensive parts searching.
Old 05-21-2011, 05:28 PM   #5
Yes, I did put 3 gallons today and still nothing.
