Wierd Noise from left side....2002 Boxster - non S
its a whinning sound kind of like a belt but it occurs only sometimes, clutch in or out, rpm not a factor and stops below 25mph instantly. It's loud and people stare.... I have shame...
bearing? axle issues, brake wear indicator? Any help as always would be appreciated |
so you can not make it occur at all while not driving? If this is the case, it has to be a wheel bearing/brakes/ or transmission. other wise if it was anything to do with the motor, you would be able to reproduce it while standing still.
Wheel Bearing
Sounds like my 2002, which had a bad wheel bearing on the right side--my mechanic knew about it because he had replaced one 2-weeks before, also on a 2002.
| All times are GMT -8. The time now is 03:09 AM. |
