-   -   1998 Boxster P0301-P0303 odb 2 reading (http://986forum.com/forums/boxster-general-discussions/28644-1998-boxster-p0301-p0303-odb-2-reading.html)
vangelo74 04-25-2011 12:00 PM
I just got a check engine light come on last week, plugged my obd 2 reader and it says P0300-P0303 cylinder misfire.
The car starts up perfect rev as usual on idle no hic ups or anything, but once i drive it and push the thottle it starts to stutter and smoke out the back. I called my garage and explained the whole thing, he says the timing jumped on 1 bank cylinders 1-3. Probably due to a worn out chain guide.
So my question is has this ever happened to anyone here or can it be something simply. My plugs and coils are new less the 2000 km, and i checked the oxygen sensors. So i have an appointment next monday at the garage but just wondering if anyone can help.
jcb986 04-25-2011 12:06 PM
I had a coil pak not seated correctly and came loose and gave me a check engine. Since you replace the plugs and coil paks I would have that checked first. Timing chain is a costly repair...engine needs to come out....
vangelo74 07-13-2011 11:23 AM
Finally got it repaired the timing chain jumped a tooth on bank 1, got both sides opened up and repaired what was needed. ended up costing 1400$ in total
